Lug Bolts
Old Apr 2, 2008 | 07:31 PM
bonez_tmac's Avatar
Lug Bolts
Anyone here ever converted there lug nuts to lug bolts? I got a good deal on some rims and tires but i just realized that they came with lug bolts. Problem is that i can't put the lug nuts on because the wholes are too small. Any suggestions?
Old Apr 2, 2008 | 07:54 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
well the holes on the hub are not threaded, rather, cogged. so you should probably get the holes on the rims enlarged, as long as the pattern is the same size with respect to the centers of the lugs, and the centers of the too-small holes
Old Apr 2, 2008 | 08:17 PM
Alex_V
No. Get new/good lug nuts and they should work. Always test fit used rims/tires before you buy them....
~Alex
Old Apr 2, 2008 | 08:20 PM
goon9's Avatar
If the the holes for the lugs are tiny, you'll probubly need 'tuner lugs' they are a more slim design.
What kind of wheel is this???? You may have some problems if it come off a car with bolts.
Old Apr 2, 2008 | 08:48 PM
bonez_tmac's Avatar
they are icw racing wheels, here they are :
http://www.icwracing.com/data/9.gif
Old Apr 3, 2008 | 03:02 AM
BenStoked's Avatar
Jesus was a Zombie.
dunno if it helps, but my lug nut holes are too small to accept an impact socket or lug wrench, so i have to use a spark plug socket, and it barely fits.
Old Apr 3, 2008 | 05:44 AM
~Alex
i just figured out what he was talking about. damn i'm dumb. i thought he meant that the lug holes were smaller diameter than the wheel studs aaaaaanyways.
Old Apr 3, 2008 | 06:08 AM
bonez_tmac's Avatar
I wish this was the case but even my lug nots are too big lol. I am going to call around to see if they have any of those "tuner lug nuts" anywhere round me.
Old Apr 3, 2008 | 06:12 AM
bonez_tmac's Avatar
Thanks man, i am going to call around to see if they have any of those.
Old Apr 3, 2008 | 09:05 AM
hoyshnin's Avatar
Baby's on the Half Tip!
haha, me too, i get it now
Old Apr 3, 2008 | 10:25 AM
bonez_tmac's Avatar
That is my fault for not explaining it properly man.
P.S Anyone knows what kinda thread i would need for the lugs?
Old Apr 3, 2008 | 11:02 AM
traxtar944's Avatar
Would be lost w/out the org
12mm X 1.25 I think...... Be sure to buy ones that have an INSIDE spline and key, not an outside one. Otherwise, your socket will scratch up your wheels while you're trying to tighten your lug-nuts. You can buy them at autozone but I wouldn't reccomend it because they rust. Get a black anodized steel set and you'll be happy.
You want THIS: VVVVVVVVVVVVVVV__NOT this: VVVVVVVVVV
Also, autocross racing does not allow closed ended lug nuts, so you wouldn't be able to compete with the ones on the right.
Old Apr 3, 2008 | 12:04 PM
BenStoked's Avatar
Jesus was a Zombie.
Originally Posted by traxtar944
... Be sure to buy ones that have an INSIDE spline and key, not an outside one. Otherwise, your socket will scratch up your wheels while you're trying to tighten your lug-nuts....
which may or may not be an issue to you, if you have the centercap for all the wheels. it wouldnt bother me personally, but i could understand why it would bother others.
Old Apr 3, 2008 | 01:01 PM
bonez_tmac's Avatar
Thanks to everyone for your help
litch
123
Jan 4, 2024 07:01 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
