Look what a shop did to my max
Old Apr 7, 2008 | 10:33 PM
mikekantor's Avatar
A bit over a year ago, before I started doing as much of my own work as possible, I had a shop replace the lower control arms along with some other suspension parts.
Over the weekend I installed ES bushings, and look at this nonsense I found:
It must've been Greeny's method but without any care or caution. Hopefully it will be fine now that its all sealed up with the goo ES supplies, but I'll probably seek a replacement gusset at a JY.
It also looked like they torqued the front LCA nuts before the wheels were down. I went completely pyro and burned all that crap out, what a huge improvement!
Old Apr 8, 2008 | 12:26 AM
Wiking's Avatar
Originally Posted by mikekantor
... I had a shop replace the lower control ...
As teen I survived one fatwa-attempt in a shop: after 'steering repair', steering system melted on a curving country road... Repair for this criminal rape-air was 30% of car value... I decided then that I can cheaply ruin my car all by myself - and that has been a lifetime fulfillment
Old Apr 8, 2008 | 02:59 AM
BenStoked's Avatar
Jesus was a Zombie.
makes the job i did on mine look professional to the 10th degree.
Old Apr 8, 2008 | 03:25 AM
maximagician's Avatar
when i was swapping a control arm for my friend that inner sleeve was stuck
on since the bushing ripped and my nieghbor came over with a big PIPE-
WRENCH which grips tighter as you push\pull and was able to twist it off
with out hurting the threads ...note*you must be buff for this to work
Old Apr 8, 2008 | 06:51 AM
Matt93SE's Avatar
STFU n00b!
That's the best way to do it actually.
what I'll do is use a wire wheel on my grinder to strip all the rubber off the sleeve, then heat the sleeve with a torch to expand it, THEN use the pipe wrench or channel locks to turn the sleeve while I'm pulling on it. after you get it 1/4" off or so, you can stick a 2 or 3 jaw puller on it and yank it the rest of the way off.
Old Apr 8, 2008 | 08:03 AM
xx-Marshall-xx's Avatar
kthxbye2u
now thats effin kool im doing it that way...
My bushing is completely gone lol the PS fluid ate it like a it was the last cookie on earth. But I have to get that big nut off first. LOL it went through 3 breaker bars and it didnt budge, so i left it. Im gonna get a impact and go to town on it when I replacing my control arms.
Old Apr 8, 2008 | 12:26 PM
Matt93SE's Avatar
STFU n00b!
Easy way to fix that...
take the car to your local tire chop shop- you know, the one that torques your wheels with a 1" impact, THEN puts the torque wrench on each lug..
anyway, take a 27mm socket up there with you- they prolly have one, but just be sure.
Ask them to break it loose for you and retighten by hand so you can get home. pay them $5 or so and be done with it. saves trying to get in there with a 10ft cheater bar.
matts95max
Apr 23, 2025 10:44 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
pktaske
May 6, 2016 07:49 AM
foodmanry
Sep 24, 2015 12:02 PM
pktaske
Sep 4, 2015 08:40 AM
