Potential Problem
Old Apr 8, 2008 | 11:00 PM
ShippedOut's Avatar
Potential Problem
Okay, so my wife had the car today and when she returned the:
Check Engine Soon
SLIP
TCS
light came on she said it came on as soon as she exited the highway and turned the overdrive off. When I turn the car off and on the SLIP and TCS light come off but turn back on minutes later. Do anyone of you guys/ladies know what the problem could be?
Thanks in advance
Old Apr 9, 2008 | 11:43 AM
n3985's Avatar
大陆弟弟
Go to Autozone and have them run the codes for the engine light.
I'm guessing bad MAF, or O2 sensor.
Old Apr 9, 2008 | 05:33 PM
larsony's Avatar
I'm almost 100% sure that your coil packs are bad. I have the same problem and I just ordered new ones yesterday. Expect to pay about $300 for all 6, or if you have more time than money you can test and replace only the bad one(s). Look at the 5th gen forum for a write-up.
Old Apr 9, 2008 | 08:48 PM
ShippedOut's Avatar
Thanks for the help.. im goin to run codes and see whats up. Ill see if my mechanic can get the coils.
If my coil packs are bad hop long can I drive untill changing them.
Old Apr 10, 2008 | 09:12 AM
MattB85's Avatar
The TCS and SLIP lights being on usually indicate an issue with the TCS system. Why would they indicate failed coil packs?
Old Apr 10, 2008 | 11:49 AM
larsony's Avatar
I know the symptoms don't seem to point towards the coils being bad, but it is actually a VERY common problem with Maxima's and I30's. Read this thread for more info:
http://forums.maxima.org/showthread.php?t=338587
Old Apr 19, 2008 | 03:47 PM
ShippedOut's Avatar
Update: It was a misfire on cylinder 5 so im getting it changed, and puttin in new spark plugs and an oil change.
Thanks for all the help .
Old Apr 19, 2008 | 03:58 PM
NmexMAX's Avatar
dot dot dot ...
What did you get changed? The coil?
Old Apr 19, 2008 | 04:12 PM
ShippedOut's Avatar
Well I have an app for monday @ 10a.m to change it out. There was a misfire on cylinder 5 so she was shaking and losing power. Im changing out that coil, the spark plugs, and gettin an oil change also.
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
