car wont turn over at all, was fine this morning...
ok so I have a few recent posts about my car. When I start it it seems like it has no juice but then starts...so I drove to work this morning and it did that, but then ran fine. I go to leave work today, and its like I had no battery at all. it tried to turn over for 3-4secs just sounded like it was real weak. then nothing. I know I have power cause all electrial works, stereo works and i can crank it up with my amp,subs no problem.
I go to crank it now, and it does nothing...
Is my starter dead? what could of possibly happened while it just sat there for 8 hours to cause it to not even try to turn over?
please help, my car is at my work still and I need to get it going asap. thanks
Maybe your altenator is finished....
Lights do come on? Batt voltage is there or is it?
If it is, try bypassing all with a jumper wire directly from + to starter solenoid. Near plus pole is also a starter loop waiting for it, check http://www.cardomain.com/ride/748507/5
yes, all wires are very tight. I have a remote start, so I popped hood and tried starting it..nothing...it tries 3 times before it stop tryin to remote start... I hit it with the wrench over and over while it was in starting process...and it started to spin, very weakly. Also when I would try this a few more times hoping it would kick over enough to start, sometimes it would just click.
I took starter out...what a ***** for being in my work parking lot with just small wrench and few sockets, bolts were on tight. Went and got a starter from parts store. $193
after tax and core returned since i had it with me. Good news! fired right up
. Starts alot better now.
Now to just figure out if I have a bad coil pack...post I have below this one from yesterday about that
Thanks guys
. Starts alot better now.Now to just figure out if I have a bad coil pack...post I have below this one from yesterday about that
Thanks guys
Thanks guys
Thanks guys
Thanks guys
Thanks guys
If you have some auto electrical knowledge, the brushes are a fairly easy replacement for about $5. Otherwise a replacement starter will fix it.
if it wasn't my daily driver and stuck at my work i could of.....damn spur of the moment problem...I wish I could of seen it coming, i probably would of replaced it before it got me stuck at work
By freak incident, my car decided to not start anymore in front of my house. Thank god. Now I don't know how the heck I can get the front on jackstands. Have you ever used the center beam under the engine that looks about 5" thick as a raising point to then transfer the load onto jackstands?
It looks slightly rusted, I'm afraid it will cave in.
Need to replace the starter. The 'battery assist guy' from CAA says I need to access it from below.
By the way, it started. He started hitting on what he called the shaft of the starter, with the end of one of those floor jack handles, from underneath at the side, and he started hitting it and it wouldn't start...then he hooked up something to my battery then started banging it from the side again and I kept turning the key maybe 20-30 times then it started.
He left then I drove it around for 30 minutes, then parked it back in front of the house, let it sit for 5-10 minutes and it won't start again.
the center beam is what holds the engine to the car...... you can support it where it meets the frame. Is there a problem getting it up from the sides (like you're parked too close to a curb or something)? Anyhow on the center member there's a little bulby thing at the front which is a owner-manual suggested jacking point. But it's always safer to put one under each front corner rather than just one up at the front. Besides you'll need a taller jack to get it angled up from way up there, than if you jacked it up farther back.
The CAA guy says to remove the drivers side wheel to replace the starter....I thought wheel ramps would be enough to do this.
In the 93 owners manual it shows jack points for the spare tire replacement...it's on the sides and under the doors. I tried to jack it up recently from their suggested spots, and the body fell right through and the jack created this crushed dent from underneath, almost a hole now.....so I don't know where to put the jackstands because of the rust.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
you do not need to take off the drivers wheel to replace the starter, as a matter of fact i don't remember jacking my car up at all.
umm not sure about the VG but I know on my auto VE the starter was very easily accessible through the top, right underneath the throttle body.
are the VG starter and VE starter the same? Im looking at the paper work and it looks like the starter I got and put in, is for the vg, according to paper work, but i compared my old bad one to the new one and they look exactly the same....
those points are for just what you said, using the jack in your trunk.
All VG auto or manual/ and all VE manual starters are the same..The only different starter on the 3rd gens is the VE auto starter.
I remember distinctly telling the guy its the VE motor DOHC, auto...because usually parts stores only know about the VG for some reason and think im an idiot when I say its a DOHC motor. Turns out this guy is a fan of the 3rd gen and was like nice, you got the faster motor blah blah blah. So I was kinda suprised and assumed he knew what I was talking about.
maybe their paperwork is just screwed up?
Maximaman - i'm getting something very strange. I've got the new starter in, and when the starter goes the car starts immediately. BUT, sometimes when I start it I get NOTHING when I turn the key. I do it again, and I get NOTHING. I do it a third time and it starts healthy. Other times today, I would go to start it and all I got is the click sound. Then try again and then healthy start.
Any ideas? I put grease on the battery post, connectors, and connector on the starter before I tightened everything down, to minimize rust, and I'm going to try and remove all the grease to see if that makes a difference.
also check things wiking listed... inhibit relay ( or possible worn bushing in the shift selector) that would cause the tranny/computer to think its in a diff gear than park, or ignition key switch
what kind of grease you put on the connections? I believe there is a special dielectrical grease for electrical contacts.
1993-VG30E-GXE: the next time it does the "no start" thing, try pushing your auto shifter up a little, you may have a bad shifter bushing causing the no start issue..
After I cleaned all the grease off of everything the first try it did the click again. 2nd try it started instantly like a gun. The last 4 times on short trips around the city it started fine on the first go.
The grease I put on is NLGI No. 2 - the one specified in the manual...Lithium EP Lubricant...it's black in color.
Also, how can I test the Inhibit Relay and Inhibit Switch? There also is the possibility that the +ve cable is deteriorated and needs replacement. Can I actually test the cable with a digital multi-meter?
Is it possible to test for a faulty Solenoid in the 'new' starter?
- Test the solenoid winding for resistance
- Starter on the floor, jump cables from batt, neg to case, pos to pos. Then jump to start pin... and wham, starter starts to run down the street... Leave supply out, and only solenoid clicks.
- Solenoid can be opened and/or changed, need soldering.
Relays are color coded. Find same color and swap.
Bypass whole system - there exist already the starter bypass wire, read linky.
Bad looking wires are replaced, u dont measure s ht.
i dont think starter had anything to do with it dieing while already running. i could be wrong tho...try tapping starter with hammer or something while someone tries to crank her over.
mine when i tried to start it would at least attempt to start again when hitting with hammer but was toast enough to not start.
maybe one of the relays under hood?
92max se? you have the VE motor?
also has the car ever given you trouble like that before (even if it similar but not exactly like this) or is this the first time it's ever acted up? some things fail over time, some fail suddenly. and of course, me being me, i had something that usually fails over time fail suddenly.
Check the ignition coils for cracks and report back.
