anyone has ground control w/ new maxima kyb?
Hey Guys,
need a little info.
My rear cattman/eclipse shock broke again.
This time I decided to replace the shock w/ a maxima application one vs an eclipse one that I have to modified, which is what came w/ the 1st gen cattmans.
Well, the cattman coilover sleeves are too big for the kyb maxima shocks, cause the two shock bodies are of different diameter.
My question is, since the coilover sleeves from Ground control is made for oem application, will it fit the maxima kyb shocks? I did not have a chance to mic the kyb vs the oem shock to see if they were close in diameter.
Also, does anyone know if the 2nd gen cattman coilover set up is made from maxima shock/struts, or are they still ones modified from another application. If the 2nd gen cattman's are indeed using maxima kyb's, I can call Brian and just get the sleeves from him.
Other wise, my other options will be to get custom sleeves made locally at a machine shop to fit the maxima kyb, or go back to repairing the broken part w/ an eclipse shock.
Some one please help me out with this. I,ve got oem springs on the rear right now, and coilovers in the front. can you say "stupid looking" ?!
thanks for any input.
Ming
need a little info.
Ming
Re: anyone has ground control w/ new maxima kyb?
Originally posted by MAC
Hey Guys,
need a little info.
Ming
Hey Guys,
need a little info.
Ming
hehe, that sucks ming, umm, i would tell if i would finally order those damn things. I am almost positive that the maxima kyb's will work with the GC's. You may have to put some different sized O rings on but they should work.
Re: Re: anyone has ground control w/ new maxima kyb?
They did say they were not aware that maxima agx were even out, and that now they will look into making a new sleeve for this application.
in the mean time, I'm still jacked up. Anyone with 2nd gen cattman's can give me any info would be appreciated.
ming
Re: Re: Re: anyone has ground control w/ new maxima kyb?
Called ground control yesterday to ask them about whether their existing max application would fit on these shocks and they said no.
ming
ming
why wouldnt it work? springs are designed to fit specically on a maxima not on struts, i just dont see the logic on why it wouldnt work with kyb's.
and read my post before this someone has installed agx's with gc coils
and i recieved my agx's today and i will install em on the 17th of this month
MAXSE5SPD
Aug 23, 2015 12:06 PM
Superbform
Aug 11, 2015 08:10 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
bassmann
Aug 3, 2015 07:53 PM
