Anybody have the 1993 FSM PDF?
nissan didn't exactly make major modifications inbetween 93/94, so whatever you need done is probably near close to the same procedure, especially under the hood, usually only interior design changes inbetween years of same gen.
93/94 are same make/model. The 89-91 models were the first 3rd gens then 92-94 were the second 3rd gens. seeing your username "1993-VG30E-GXE" you have the same engine the SE(89-91) and GXE(89-94) have. I don't think anything engine related changed between 93 and 94.
If you post exactly what it is you are looking for, it might be even easier for someone to help you out with it.
there was ONE change that i know of for 1994, but that was just the shape of teeth on the timing belt sprockets. 89-93 round, and 94 square. Someone correct me if i'm wrong about that.
heh sorry. when i first saw the thread there were no replies, but i went outside, pulled that engine i PM'd you about (chain routing worked great, btw), came back inside, and clicked reply without refreshing the thread.... so a few ppl had replied within that time
It's cool
As far as vg's go I think your right, all they changed was the timing belt sprockets. Which I'm in the market for a 1994 vg timing sprockets.
i really should get an earlier fsm tho b/c i probably won't have a post-91 max for a while.
No round is much better. I donno if i wasn't clear?
James92SE
Oct 8, 2015 04:57 PM
The Wizard
24
Oct 1, 2015 08:47 PM
