Is it True That Injectors Rarely Need Full Replacement But Just Re-Build & Calibrated
cause i have a remanufactured rack and pinion and rear calipers. No problems as of yet
Any remanufactured part from the 'big chain auto parts stores" are a coin toss in quality, mainly injectors and alternators are the big " junk" items at the chain stores, especially injectors. You should be just fine with your reman rack unit and calipers .
rebuilt injectors are junk for the 3rd gen no matter who they are from.
starters/alternators that are rebuilt from the big box stores are also typically crapola.
I actually don't care for reman items in general. Especially stuff that is cheap. there is only one way to get a cheap reman part and that is by sacrificing quality.
Mau. Since this thread was/is about injectors, I did not feel it necessary to say "injector" in my post.
sometimes something they "fix" actually works. seriously, a starter is not that complicated, so rebuilding it should be easy for people who do it all day(then again you would think they would make a burger or drink right at the fast food joint, thats all they do.)
WRT title of this thread .................
If you ever had an injector in your hands, it should be obvious that other than simply cleaning the terminals and running a cleaning solution (acetone or toluene etc based stuff) through its mechanical bits, there is nothing that anybody can do to the thing to improve it "performance"
At best a "re-manufactured" injector is thus a cleaned injector.
Injectors cannot be "balanced" - nobody can get to either the electrical coil or the pintle seat to tweak any parameter without disassembling the metal body of the injector (destructive process) and then having to manufacture a new metal body.
Injectors cannot be "rebuilt" at even a fairly high price because the mechanical construction of the metal body makes it financially uneconomical/impossible to do compared to the price of new units.
so yea even tho they make starters every day, if they get into a habit of not doing them right... they never end up right.
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
maxinout93
Aug 20, 2015 02:17 AM
