1/0 gauge adapter
Old May 15, 2008 | 12:28 PM
myer84's Avatar
1/0 gauge adapter
Hey guys,
I been working on my setup for quite a time and taking my time to get it right. I'm running 1/0 guage to the trunk. The cable wont reach the amp so I need to add another 3 feet to the existing cable. Is there some kind of adapter I can use where I could connect both pieces togeter? I have googled and only come across items that only accept up to 6 gauge and they are not meant for automotive use.
Also, any ideas on a quick disconnect method? I would like to quickly disconnect the power, ground, remote, RCA, and speaker leads in one easy plug. I want to do this so that if I ever need to remove my amp to access my spare or go to the track to get rid of the extra weight I could simply unplug everything from one location. I'm too lazy to unscrew from the amp, Lol.
Thanks in advance
Old May 15, 2008 | 05:15 PM
MadMaxSE-L's Avatar
Doggah Bite...
Maybe you could use a fuse holder as a coupling?
How much wire did it take to get from the battery to where you are now? I just bought ~21 ft of 0ga wire and am hoping it is going to be enough to do my whole 97 Maxima...
-Matt
Old May 15, 2008 | 05:18 PM
AscendantMax's Avatar
^ 21 ft should be plenty.
and +1 to a fuse holder as a coupling.
Old May 15, 2008 | 05:31 PM
BLACKonBLACK98's Avatar
Former Vendor
+2 on inline fuuse holder. another cool idea is a circuit breker so if you're playing around in your trunk you can trip the breaker and not have to pull the fuse from under the hood.
Old May 15, 2008 | 07:02 PM
travmaximas1998's Avatar
:+1:
like the circuit breaker idea i get tired of taking my fuse in and out but o well
Old May 16, 2008 | 05:31 AM
myer84's Avatar
[QUOTE=MadMaxSE-L;6410909]Maybe you could use a fuse holder as a coupling?
-Matt[/QU
I only got 16 ft. I should on gotten at least 18
Old May 16, 2008 | 05:35 AM
myer84's Avatar
I like that idea. I will definatly look into that.
As for the quick amp disconnect idea I though about buying those 3 prong power sockets (male and female) and use the prongs to hook up my power, ground, and remote. I will test this out and see how it works.
Old May 16, 2008 | 08:40 AM
sounds like a possiblity
Miket2006
Mar 1, 2021 03:55 AM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
RWCreative
Sep 21, 2015 11:01 AM
