Valve Cover Gasket Question
I have heard almost a 50/50 split on whether or not to use gasket sealer in addition to the ruber valve cover gaskets on the 97 max. What do you guys know? Also, how do i judge how tight to screw in the bolts so that the gasket doesnt end up too compresses or not enough? TIA
I used high temp orange gasket, some more at the corners and a thin layer on the whole edge of the CH. I torqued the bolts by hand, not too tight, not to loose, when the wrench stopped went 1/4 more. No leaks so far.
PS: first time I did this I used blue gasket only at the corners, and had some leaks.
Like stated above, the FSM directs you to use RTV in the corners, I would also recommend a light strip all the way around. It won't hurt, just make sure you actually torque the bolts using a torque wrench, I know some people say it is pointless, but you can never do a good job unless you actually torque to spec. Either rent one at autozone or buy a cheap one at Harbor Freight, they are actually decent quality.
I like red RTV, permatex is a good brand, it is high temp and flexible enough for the application.
1st try- I did it as per fsm -and it leaked worse than before so 2nd time I put a light
film of Permatex gray all the way around on top of the gasket -stuck it into the groove-
and put a light film on the bottom of the entire end (timing chain side) and then an additional bead maybe 1 1/2" at the corners again at the Tc end . Torqued it ever so
carefully in two steps as mentioned by unclemax98 and left the Permatex dry overnight
and both vc covers have stayed completely dry since (about 10 k miles).
(just make sure INCH POUNDS not FOOT POUNDS)
I could clearly see it when I took the valve covers off and this was the
first time the covers were ever off (I'm the original owner) and it's specified
in the fsm.
Regasket, RTV, throw it back on. Extremely simple job.
FWIW, I only use a torque wrench when doing motor builds, 99% of everything else can be done by feel, impact, or impact + torque sticks.
Oh, I don't doubt it. Just saying I never noticed it, and also sharing my experience with one WITHOUT any sealant for the past few years.
For the front? 20 minutes. 10mm socket and ratchet, and a pair of pliers to get that breather hose off.
Not too hard if you've got the right tools and a bit of time on your hands.
If you are doing the rear valve cover, I would recommend using a cable hose clamp plier like the one here:
http://www.sears.com/shc/s/p_10153_1...pecialty+Tools
Make sure you get the manifold gaskets also, as long as you label and take your time, it is not as hard as you think.
4 bolts, a wire harness, throttle cables and intake piping, and the UIM will pop right off.
Valve cover gasket
I'm new here and am having my mechanic change my plugs. If there is oil on them, then I'm assuming the valve cover is leaking...correct? Hopefully my rear one isn't bad...
dude, it takes like 10 minutes to change em out. and if theres oil of the plug, its your tube seal
lol...funny guy.....
also, i put the valve cover gasket on and put some of that gasket sealer and put everything on....i drove for like 2 months and relized i messed up on the spark plug area so i took my front one off again, and like 3" of my valve cover gasket was missing.... 3 inches!!!
i looked into the head, nothing, and behind by the fuel injectors, nothing....WTF? but i changed it again....but now that i replaced it and put NGK's, i fell in love all over with my car....execpt the body part....still messed up
do you over tighten it or something?
That would be the best way to go, yes. Ideally, you'd only need the first...the UIM-LIM gasket is thick rubber, and I've reused mine many many times without any leaks, and the IACV gasket is metal...also not too prone to leaking. If you plan to reuse be sure to check the gaskets you are reusing to make sure they look alright.
For the rear, ratchet, 6" extension, 12mm and 10mm sockets (short or deep 12mm, short will work best overall), flathead.
Remove intake hose, IACV (much easier access to EGR bolts), two 12mm head EGR bolts, 2 12mm head intake manifold support bracket bolts, 4 12mm head fasteners on the front of the manifold, then unbolt PCV, throttle cable bracket, wiring harness brackets. Move wiring harness to lay over by the PS reservoir, lift UIM out of the way. From there, same as the front.
03VQMAX
Sep 5, 2015 03:47 PM
lol, good stuff, good stuff!
