Getting noisier......
Old Jun 5, 2008 | 11:24 PM
t65k3's Avatar
Still Learning
One of the fans died, and the temp shoots up when idle during hot days. The whole fan assembly was replaced today. Both fans work fine now, and my max is cooled good. But..... it's awfully noisy.
I am gonna describe how they work now in case I messed up the wiring.
When I start the car (car is cool), both fans don't run.
When I turn on A/C, both fans are on but in a lower speed. (acceptable noise)
When the A/C is on and car is hot, both fans turn in a even higher speed. (Very Noisy, I could even feel the shaking caused by fans while stopping at traffic lights)
One of the old fans had died for almost a year. So I could not remember if the noise I hear now is normal or whether the new ones are working the way they should be.
Maybe they are a bit louder but work fine?
Thanks in advance......
Old Jun 6, 2008 | 06:42 AM
maxblk99's Avatar
car shouldn't shack or anything with the fans on. Were the rubber isolaters reinstalled? Is the noise you hear inside the car or from outside? I can hear my fans spinning from outside but not inside the car.
Old Jun 6, 2008 | 07:44 AM
rxm6's Avatar
Were they aftermarket or oem? I once installed an aftermarket fan into my jag and it sounded like a P51 on takeoff. I eventually had to buy an oem one because the aftermarket noise was unbearable.
Old Jun 6, 2008 | 09:05 AM
abomb1987's Avatar
there should be rubber grommets that hold the fans to prevent shaking, are they installed?
Or it could just be a bent fan blade, or one of the fan blades are not aligned, causing the noises.
Old Jun 6, 2008 | 11:32 AM
Snypa's Avatar
fans need an alignment.
Old Jun 6, 2008 | 12:47 PM
t65k3's Avatar
Still Learning
It's a aftermarked gotten from Autozone.
On top corners of the assembly I see the rubber isolaters. They are a little old so they don't hold the assembly too well. The assembly could actually rattle a bit in there. I suspected that and now I know they need to be replaced. That should solve the shaking/rattling problem. Thanks for the help, guys.
As for the noise, is there a period of time that I could return the part in? It's been installed and I'm afraid that they would not take it back. Man, OEM would suck me dry even more.
Old Jun 6, 2008 | 02:29 PM
rxm6's Avatar
Originally Posted by t65k3
It's a aftermarked gotten from Autozone. Man, OEM would suck me dry even more.
There's your problem. I noticed aftermarket fans aren't as solid as they should be and they tend to wobble. Nothing to damage your car, but just enough that are noisy as hell. OEM is always the way to go. If you don't have enough to buy a new one, why not get a used one from a donor car or a part out here on the .org?
Old Jun 8, 2008 | 10:46 PM
t65k3's Avatar
Still Learning
I agree......
What's the part circled called? I think by replacing those two it would help a bit, since the old ones are old......
