abs light on 97 nissan maxima
Old Jun 26, 2008 | 07:33 PM
hiren_patel_83's Avatar
Has anybody has this issue? My ABS light just recently came on my 97 nissan maxima.
Please let me know if anybody has had this issue and what they did to resolve it.
Old Jun 26, 2008 | 07:42 PM
modenaf1's Avatar
I've had it happen on all my cars, usually from some dirt or snow getting packed in the ABS sensor ring though.
Old Jun 26, 2008 | 07:53 PM
ok good to know. now i need to find out where the sensor ring is located. Would you know?
Old Jun 26, 2008 | 08:51 PM
99BlackMaxMS's Avatar
You need a new ABS sensor. $168 at your local dealership, and yes, they are the only place to get them new.
Check the FSM to see how to pull the codes to get which wheel the faulty sensor is located at. If it is a front wheel sensor, then you are going to either have to buy a new hub from a crashed Maxima with ABS or an i30. If it is a rear wheel sensor, contact fanaticrockford as he has them used for dirt cheap.
Old Jun 26, 2008 | 09:12 PM
Just curious, but are you saying that a new hub has to be bought in order to get the front ABS sensor (not sold seperately), or am I not understanding you correctly??
Knock on wood that I don't have this problem, but one day I fear I will.
Old Jun 26, 2008 | 09:15 PM
Thankfully, no a new hub is not needed. It is nearly impossible to get a front ABS sensor out without destroying it, which is why it might be easier/cheaper to buy a front hub assembly from a Maxima with ABS or an I30. I spent the $170 on the sensor over the winter and the light went away and my ABS came back
Old Jun 26, 2008 | 09:21 PM
Gotcha. Thanks for the explanation.
Old Jun 27, 2008 | 06:49 AM
thanks guy, i'mma go buy a abs sensor and see if it helps.
Old Jun 27, 2008 | 07:14 AM
modenaf1's Avatar
Do you know which one? Also check it out before you buy a new one, I swear with mine it was a matter of hosing off that area at a carwash and my problem was solved.
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
kjm900r
Aug 5, 2015 07:14 AM
