Part out: 1997 GXE 5sp manual
I'm 600 miles away from the car right now. I won't be able to do anything till I see the car around Christmas.
Complete part out. White exterior, black interior, gray cloth. Let me know if there's anything you need that's not listed. Prices include shipping. Paypal (thurznite@yahoo.com), money order, cashiers check accepted. Higher priced items negotiable, make me an offer.
Sold items in lighter color, like this.
Air Conditioning
Compressor with clutch, 3months old: $137
Expansion valve, 3 months old: $14
Alternator/Charging
Nissan Alternator, from the recall: $74
Belts & Hoses
Idler/Tensioner Pulley 3months old: $13
Belts: name a price
Body & Trim Parts (interior/exterior)
Rear Bumper Cover: $121, pickup only
Mirror Replacement Glass: $9
Replacement Mirror (Left black/Right white): $31
Window Lift Motor: $25
Window Regulator: $27
Center armrest lid: $49
Shift boot: $30
Lighter Assembly: $13, element: $4, illuminated ring: $4
Cupholder, black, with lid: $26
Parking brake cover, black: $25
>>>>>>>>>>>>>$150 for everything including the big console itself.
***Instrument Panels***
Center vent grill: $59
Stereo trim panel: $27
Radio Pocket with lid: $12
Radio Pocket w/o lid: $11
Ash Tray: $10
Instrument Cluster lid: $67
Fuse box door, black: $5
Roof/Door weather strip, left/right: $22 each
Bumper/headlight weather strip, left/right: $11/each
Brake Hardware
Parking Brake Cable Left/Right: $41 each
Brake Caliper, Rear, Left/Right: $48 each
Brake Caliper, Front, Left/Right: $24 each
Brake Hose, Goodridge Stainless Steel Braided: $66
Master Cylinder: $34
Power Brake Booster: $86
Chassis
Lower Control Arm, Left/Right: $72 each, $79 with ball joints, $15 for ball joints
Tie rods: Name your price
Hub, left/right: $61 each
Clutch, CV & Drive Shaft Parts
2001 5sp manual transmission, 60k miles: $700. Ask for 5sp swap price.
Stainless Steel braided clutch hose: $12
Clutch Master Cylinder: $34
ACT Street clutch pressure plate + disc: $90
Clutch Slave Cylinder: $20
Drive Shaft/Axle, non-abs, non-lsd, left/right: $33 each
Flywheel: $33
Cooling & Heating
Blower Motor: $65
Heater Core: $90
Thermostat: $12
Water Pump, new, 1yr warranty: $88
Radiator Fan Motor (shroud/motor/blade): $73
Emissions
EGR Valve: $60
Oxygen Sensor, 1yr old: $32 each front, $42 rear
Vapor Canister: $31
Engine Parts & Mounts
Engine: $400
ES Energy Suspension Engine Motor Mount (already pressed in): $84
Exhaust
Stock Catback, Resonator, Muffler: Name your price
Hi-flow cat: $48
Exhaust Manifold/Header, Left/right: $49 each
Y-pipe, CA spec: $173? It's a big piece to ship! Make an offer.
Fuel Injection
Idle Air Control Valve IACV: $103
Fuel Pump
Fuel Pump: $68
Fuel Pump Strainer: $12
Fuel Tank: $147 pickup only
Ignition & Tune-Up
Ignition Coil, 6 total, 1year old: Front~$41/each, Back~$49/each
ECU/computer, 97 GXE 5sp CA: $310
Lamps/Flashers/Fuses
Turn Signal/hazard flasher: $6
Rear license plate light: $19
Relays
A/C Compressor: $7
A/C Blower: $7
Rear Window Defogger: $9
Fuel Pump: $7
Headlamp: $14
Horn: $6
Sensors
Air Charge Temperature: $18
Mass Air Flow: $121
Camshaft Positio: $44
Coolant Temperature: $9
Crankshaft Position: $35
Knock: $92
MAP-Barometric Pressure: $103
Vehicle Speed, 5sp manual: $19
Throttle Position: $49
Boost: $103
Shocks & Springs
Sprint Springs, Tokico Illumina Struts, Nissan Mounts, Nissan boots/bellows, whole assembly: $300
Starters
Starter, lifetime warranty: $76
Steering
Pressure Line Assembly: $27
Power Steering Pressure Switch: $37
Pump: $97
Rack & Pinion: $157
Tie Rod End - Driver, Inner: $7
Tie Rod End - Driver, Outer: $9
Tie Rod End - Passenger, Inner: $7
Tie Rod End - Passenger, Outer: $9
Switches
Ambient Air Temperature Sensor: $37
Blower Control Switch: $33
Blower Motor Resistor: $20
Headlight switch: $43
Ignition Lock Cylinder: $57
Ignition Lock Cylinder Switch Assembly: $79
Ignition: $24
Backup/Neutral Safety: $18
Oil Pressure Switch/Sender: $5
Power Steering Pressure: $37
Rear Defogger Switch: $25
Stoplight Switch: $5
Exhaust Temperature Sensor: $78
Water/Coolant Temperature Sender: $99
Accessories
Floor Mats, Gray: $40
***************** Will post more tonight
Dr J
Air Conditioning
Alternator/Charging
Belts & Hoses
Belts: name a price
Shift boot: $30
Ash Tray: $10
Brake Hardware
Chassis
Flywheel: $33
Cooling & Heating
Blower Motor: $65
Heater Core: $90
Thermostat: $12
Emissions
EGR Valve: $60
Vapor Canister: $31
Engine: $400
Exhaust
Hi-flow cat: $48
Fuel Injection
Fuel Pump
Fuel Pump: $68
Ignition & Tune-Up
Relays
A/C Compressor: $7
A/C Blower: $7
Fuel Pump: $7
Headlamp: $14
Horn: $6
Sensors
Mass Air Flow: $121
Knock: $92
Boost: $103
Shocks & Springs
Starters
Steering
Pump: $97
Rack & Pinion: $157
Switches
Ignition: $24
Accessories
Dr J
The flywheel is the original one, it does have the ring. Prices updated. There's 1 person who's asking for only the driver axle, so if you want it, send me $ before he does. Yes, I have everything for the swap. See my sig for package price.
Not looking for a full package right now (have some stuff already, possibly getting a trans locally for ~$50, etc). Will you split up the shifter/rods/trim?
i meant a live photo of the wheel so i can see if it is in $255 condition. And that illustration is for a 95 or 96 so help me out. I am looking to spend 150 the most iand that is mint condition. If that not doable i understand.
no email or pm yet email is chrlsmccrthy@yahoo.com let me know when you get a chance, thanks ,chuck
