*WTB* Custom harness/wiring kit for r34 headlights
I'm wondering if anyone can make me a custom harness/relay kit, right now I have a plug and play HID kit in the low beams(9006) but my high beams are non functional. Can anyone make me a harness where I can turn on the hi-beams and keep my lo-beams on at the same time?
PM me more info/price...
I can send out the original r34 harness if necessary.
Thanks!
Thanks!
Here's a simple diagram...
RED - how the car is currently wired
BLUE - not in use at the moment
any ideas? any other questions just ask...
I want to utilize my high beam, BUT the main thing that I want to emphasize is that I want BOTH low and high beams to be on when I activate the high beam. I know with the stock 9004 setup the low beam filament turns off when the high beam is activated...is it even possible to have both functional?
You can find the diagram on hidplanet.com This is where I found mine. I made up my own relay all soldered connections. Takes a few hours to make up so expect to pay someone $70 or more to do. You will need a diode to keep your high beams on when you flash I believe.
70 is cheap. I think the relays,diodes,and wire cost me 35.So yea 70 is on the low side. I plan to make it pretty.
Yeah your right it is on the low side considering the material you need. I have to snap a pic of my harness NIIICCEE!! but unfortunately Im limited to where I can mount my ballast and Ignitor do to OEM wires being short but oohh well...lighting works flawlessly and that what counts.
t6378tp
Sep 29, 2018 04:27 PM
carid
Sep 17, 2015 05:00 AM
