Pair of Infiniti G35 Coupe Seats - Black Leather - CHEAP!!
Old Jul 23, 2008 | 10:54 AM
01Bblack's Avatar
Selling a pair of Infiniti G35 Coupe Seats in Black Leather - No rips/holes/cig. burns/e.t.c. -
With minor modification they will fit into the 4th generation maxima (using your seat rails) - They are taking up space in my basement so I'm pricing them at $350 for a very quick sale - (I'm sure this is the cheapest set of G35 Coupe seats on the net)
Your car can look like this:
Seat pictures follow:
Seats are:
Black Leather
Power
Heated
Airbags
Head rest included
**Note- these can be simply wired for power by tapping the ciggarette lighter
$350 picked up - I can meet around Philadelphia in the next 2 days.
Email: C.bells@gmail.com - I will respond promptly
Old Jul 23, 2008 | 11:22 AM
95stillenmax's Avatar
great deal
Old Jul 23, 2008 | 07:53 PM
elgordito941's Avatar
Aw no head rests??????? itll look funny with 4th gen heads lol Free bump maybe if i decide to spend the time to find other head rest il shoot u a pm
Old Jul 23, 2008 | 10:37 PM
01Bblack's Avatar
Head rests are definitely included... (See Pictures)
Old Jul 24, 2008 | 07:29 AM
Fr33way™'s Avatar
Wild for Width
Very nice seats at a good price.
Old Jul 24, 2008 | 08:29 AM
B_Eaze's Avatar
i always see these deals and there never near me. When the are i usually can't afford to get them. Nice deal
Old Jul 24, 2008 | 02:09 PM
Problemchild1one's Avatar
where u at how are they in a 4th gen i wanna buy shoot me a pm bro
Old Jul 24, 2008 | 07:33 PM
01Bblack's Avatar
Located near Philly- to fit 4th gen you need to use your existing seat rails
Old Jul 24, 2008 | 07:36 PM
maximullins's Avatar
Why you getting rid of them? I've got a nice set of Honda Civic seats that would look sweet in your G35 ;-)
Old Jul 24, 2008 | 09:30 PM
KyleFort32's Avatar
how hard to get into a 4th gen...major modification please explain shoot me a pm
Old Jul 24, 2008 | 09:57 PM
maximariceboi's Avatar
where are you located?
Old Jul 25, 2008 | 04:15 AM
B_Eaze's Avatar
do a search, i think theres actually a link in the interior sticky in the 4th gen section for the install write up
Old Jul 27, 2008 | 07:43 PM
01Bblack's Avatar
Lots of interest - No Buyer!!! - Location: Near Philly.... def take a look at the stickies there are a couple of how to's on installing g35/350z seats
Old Jul 27, 2008 | 07:53 PM
01Bblack's Avatar
As taken from a previous post- the install:
Perhaps the summary of my installation may help? The way I installed it (as well as the other member whom put in the 350Z seats into his 4th Gen). Start with the passenger side seating>
1. Take the I30 seats out from the car to the livingroom
2. Take off headrest.
3. Take out the plastic panels around the powerseat (few screws)
4. Disconnect the harness btwn back cushion & lower cushion
5. Take off the back panel of the stock I30 seats
6. You will be able to access to the bolts/nuts that holds the stock back cushion in. If you have side airbags, be careful and go to the bottom and un-hook what's holding the harness for SRS side airbags, heated seats and power seats, etc.
7. After losening the nuts and bolts (I believe 2 on each side = total 4?), you should be able to slide the stock seat cushion out where it supports your back.
8. Then you will have to go do the same thing, carefully disassemble the lower portion of the cushion from the seat pan.
9. Now you have a clear view of where and how the stock OEM seats were assembled and remember how you disassmbled it.
Take a look at your 350Z/G35 Seats
And start from the back for the cushion by unzipping the leather/clothes off the rear of the seat cushions. You can access to the nuts/bolts that holds it to the stock 350z/G35 seats. Do the same thing by taking the top cushion off first, and then disassemble the bottom cushion.
Once you have them apart (I did NOT use the stock G35 power switches)> I zip-tight the leather gap. Now you have to test fit the top cushion to the BAREBONE of the Stock OEM I30 seat pan and the metal support. You will see where you may have to screw the new bolts or drill new holes to hold the bolts and nuts to have it mounted securely.
On the bottom cushion, it's similar as putting the aftermarket leather onto the car, and use the stock seat pan to connect with the leather... if you have disassembled 'em, you will see there were alot of "O" rings that connnects them> I used them as well as putting zip-tides strings to fasten the two pieces together. Also I have put in some extra foams below the G35 coupe seats to make the seats firmer and more supportive to my butt.
Email me if you run into any problem. Maybe I can explain to you how to get it done?
SY
sycefiro@yahoo.com
Old Jul 27, 2008 | 10:30 PM
Nightkid08's Avatar
how much would you charge for installation?
Old Jul 28, 2008 | 09:32 PM
01Bblack's Avatar
Not sure I would like to install personally (I'm not a shop lol) - To the top!
Old Jul 31, 2008 | 05:13 PM
SYCEFIRO's Avatar
Hey.. that's pix from my I30's (2 pix)..... & my instructions....
Hahaha... if you don't get these sold in 1wk... I'll have to pick 'em up
Good luck
SYCEFIRO
PS. where are you located at?
Old Aug 1, 2008 | 01:05 PM
01Bblack's Avatar
lol had to use your pictures... (since you did so well and all)
Old Aug 6, 2008 | 07:54 AM
sergofast's Avatar
when you say that you must use your factory seat rails does that include the motor mechanism that operates the bottom seat? Mine is going bad in the driver side.
Old Aug 11, 2008 | 07:13 PM
01Bblack's Avatar
Sold!
GregL65
Sep 5, 2015 09:37 PM
DrVee
Sep 4, 2015 12:18 PM
lux97Max
Sep 3, 2015 04:51 PM
A32goldylocks
Sep 2, 2015 06:39 AM
