Rear chrome strip
I actually took mine off a while back to fix a rattle. Open the trunk, remove the upper liner and you should see some bolt studs. Take the nuts off and it should pop right off. I recall having to take the whole assy. off to do it though (license plate holder and all)
Additionally, I think if you want to use the I35 piece, you'll also need the I35 license plate holder/finisher panel as well as the I35 inner tails (and really full I35 tails for aesthetic purposes).
I tried taking mine off once and I couldn't get it out in the time I had allotted. I think if I had a panel popper it might have been easier.
I couldn't tell you how, but once I had a small rock stuck between the license plate panel and the actual metal of the trunk - so basically, the rock was behind the license place. I tried to take off cover piece, but its actually plastic and very fragile. The rock is still stuck in there because I didn't want to risk breaking that piece.
Just be careful, it will shatter very easily if pulled the wrong direction.
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
