brakes acting weird. First pump Low to floor, 2nd much higher?
I did everything you can do besides replace the lines and Mas cly. I have bled and bled and I really can't bleed anymore because I just can't be pissing out Dot4 like that. Anyway, When I first press my pedal it goes pretty low, but If I press it again real quick is is nice and firm were I like it. Is that just trapped bubbles or a bad seal? It aggravates me a great deal because I put over $700 bucks(replaced everything beside wat I mentioned)into these brakes in the past 2 years and I just can't seem to get them to work right. lol
Not to mention I found out that I didn't need new rear calipers I guess, because the Parking brake cable on one side was rusted to ****. Eventhough my brembos were glowing red from it. So I thought it was calipers. lol
So any guesses?
So any guesses?
It sounds like it could be the lines then, if there is a crack in the line it would fill up with air and the bleeding would be like scooping buckets of water out of a hole and a wave coming back to fill it up (sorry for the lame comparison its all i could think of)
this sounds like a case of needing to bleed.
I am sure you have but man thats what that sounds like .sometimes it can be a bit of a pita to get the air out. my suggestion would be to bleed them again,starting with the passanger rear. bleed them good and slow. pumping the peddle really fast (as I have seen many people do) can cause the fluid to kind of foam up,once it clears you have air in your lines again.
hope this helps
hope this helps
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
bbsitum
Sep 11, 2015 04:55 PM
