SMC Short Shifter Installed. very Stiff, very noisy.
Hey guys, I have my short throw shifter installed, and its very stiff (understandable), and its very noisy. I can't tell if it's scrapping or tapping the heatshield. I don't have it at the lowest setting, I'd say it has another 1/2 inch to go. I was wondering all you guys with proper installs, did you experience, or do you still experience any extra noise from the shifter. Its almost sounds like a hollow tapping sound, but I dont feel as if it hits anything. By chance, can the SMC shifter be adjusted without going underneathe the car?
Thanks.
Thanks.
Re: SMC Short Shifter Installed. very Stiff, very noisy.
Thanks.
Thanks.
Re: Re: SMC Short Shifter Installed. very Stiff, very noisy.
Originally posted by RussMaxManiac
The shifter will eventually break in. But to help mine a I put Redline MT-90 on the ball once it was installed, let it soak in, with some mobil 1, and man it made it really easy!
Re: Re: Re: SMC Short Shifter Installed. very Stiff, very noisy.
I think its tapping on the heat shield.
Re: Re: Re: Re: SMC Short Shifter Installed. very Stiff, very noisy.
You would defintely know if it was hitting that shield. You would hear a bang from the outside. 4th gear is the one and R that usually hit the shield if its too close. Pop it in those gears fast and listen for a metal sound.
jmlee44
Oct 2, 2022 02:13 PM
atriuum
Sep 28, 2015 01:19 PM
