tire clearence
Old Nov 26, 2008 | 11:30 PM
sergey85's Avatar
tire clearence
im in the process of getting some 07 350z rims from my freind. they are 18x8.5 and i know for sure the fit but im not sure about the tire clearence. they originaly came in 225/45/18 on front and 245/45/18 in the rear. now if i go 245 all around would that give me any problems, would i get any rubbing issues. thanks appreciate the help
Old Nov 27, 2008 | 12:36 AM
IHAVEA2KMAXIMA's Avatar
I think you will need to roll the fenders because when you hit a bump, your rear tires might rub. Are you lowered?
But anyways, that combo should be fine.
Old Nov 27, 2008 | 10:41 AM
sergey85's Avatar
no im not lowered, yeah i was worried about the fender too, u think i should just go with 225 all around?? i mean mine are 215 right now on the stock 17
Old Dec 10, 2008 | 08:21 AM
speedymax99's Avatar
you should be fine if your stock
Old Dec 10, 2008 | 08:53 AM
black_maxed95's Avatar
not trying to thread jack but I have a similar question. I currently have 225/45-17 and Im lowered on Illuminas/S-techs all around...will it be ok to do 225/50-17? I found a deal on some snow tires in this size.
Old Dec 11, 2008 | 01:36 PM
any input? Im a noob at knowing what tire sizes fit.
Old Dec 11, 2008 | 02:18 PM
MrDicks95SE's Avatar
Offset Is Everything.
you'll be fine with that size on stock height. no rub.
Old Dec 11, 2008 | 02:20 PM
stay 225/45-17. youre as close to oe spec as can be. going larger sidewall will throw you speedo and odo off.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
