6the gen wheel qustion about 20"s
just wonderin if anyone can answer this i wanna go woth 20"s what is the max size tire i can go with on the rear and the front? and also what would be the rim offsets and rim size i would get? I seen this guy with a 6 gen put 20/10 on the rear and also dont know what offsett or tire size he is runnin.
Please dont stagger....
You can answer all this on your own, go to your car and do some measuring of your stock wheels with respect to your suspension and fender clearence. Find your wheels specs ( simple search) Then use the new wheels specs in combination with the offset calculator on the top of the page. Use your previous measurements to see if it clears, its that easy....
Edit: Looks like that work has been done for you
http://forums.maxima.org/showthread.php?t=387627 Once again, please dont stagger, its useless on a FWD car, unless your drag racing and run slicks up front..
I have 20X9 with 40 offset rims all the way around. And my tires are 255/35/20. I'm not lowered but another member is lowered on eibach springs with the same exact rims and tires i have. So there ya go.
So do your 255/35/20 tires rub when you turn or bottom out in the back when you have a heavy load?
You can go with 245-40-20 that will give you alittle more meat.. That will work all around...
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Oct 15, 2015 08:01 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
