question about tires for staggered wheels (plz help)
Old Dec 21, 2008 | 10:36 PM
OC guy's Avatar
2002 maxima se
I need to buy tires for my 17x7.5 and 17x8 wheels, currently i am running stock tires 225/50/17 all around. What size do you recommend for those staggered wheels...? how efficient is 225/45/17 in the front and 245/40/17 in the rear sounds? Thanks.
Old Dec 22, 2008 | 12:13 AM
MrDicks95SE's Avatar
Offset Is Everything.
if you want to be able to "rotate" the staggered setup, you can run 235/50 all around. it will make things more "efficient" so to speak. if not, then you can run that 225, 245 if you'd like. personally id run 235's all around since it's not an aggressive stagger.
Old Dec 22, 2008 | 05:42 PM
OC guy's Avatar
2002 maxima se
thanks but my car is lowered around 1.7'' in front and 1.5" rear if i go with 235/50 wont that cause any rubbing? what about 235/45?
Old Dec 23, 2008 | 11:19 AM
Fast1one's Avatar
Depends on the offset of the wheels, but I seriously doubt you'll run into problems unless you have offsets below the 30s...even if you do, just roll the rear fenders
Old Dec 23, 2008 | 03:16 PM
OC guy's Avatar
2002 maxima se
the offset is around 30's plus 5mm spacers in the back, the wheels sits out flush though. I dont like tires with tall sidewalls, i think 235/45 will be better.
02nissmax
Sep 5, 2015 01:50 PM
homeyclaus
Sep 3, 2015 06:15 PM
gizzsdad
Aug 19, 2015 01:01 PM
twotonezed
Aug 16, 2015 11:41 AM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
