hid question
hid question
do the factory hid start going dim as they get old? reason i ask my bother just bought some 6k for his rsx and they seem to be 3 times brighter than mine. makes my hids look like stock bulbs so is it time to replace them? thanks
Are you comparing 4300k to 6000k? Also are you looking at color or viewable light?
it doesn't really matter..as time goes on, the viewable light diminishes...as far as color, naturally the HIGHER you go in the kelvin scale, the less USABLE light you have to start off with
since we are on the subject..... can the stock hid bulb be replaced with one of the higher temp ones, such as 8000k or 10000k without swapping the ballast?
oh and by the way, all bulbs begin to lose brightness from the day they are first turned on, that even includes lcd tv's home theater projectors and so on. the only bulb that keeps its intensity throughout its life span are led.
yes you can swap bulbs...it doesnt matter what kind of ballast your using, as long as the bulb works with a 35 watt ballast your ok to go bro
and in ACTUALITY, the LCD doesnt loose brightness throughout its life span because it doesn't control brightness....its the backlight your referring to
Jeez.... gettin all technical on me
yes its the backlight that gets dim, there are lcd panels that use led's as backlight that do not get dim over time and there expensive as hell. And there are projecters and projection tv's that are using led bulbs that do not dim, I will remember to be more specific
..... yea you are absolutely correct with all the other info.....i only wanted to bring that up becuz of the ppl that wont READ the entire post and WILL ASSUME that LCD's themselves dim.....you know the ones im talking about, lol
this thread = FAIL.
do some reasearch about lighting before posting.
start with this excellent and informational link from a well-respected authority on the subject:
http://www.danielsternlighting.com/t...lbs/bulbs.html
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
