My passenger front door won't lock - Door Motor?
So ever since it got really cold, my passenger front door will not lock.
The locking lever (near the inside door handle) moves...it just doesn't move far enough. I can push it the rest of the way (or pull it) to lock/unlock the door. But by using the remote or driver side master switch, it will not lock/unlock completely.
I took it apart two days ago and sprayed WD-40 on the part where the two metal links meet and go down to the motor I presume. This fixed the problem for 1 day. Obviously, I can't keep doing this. Is it my motor that just doesn't have enough juice to pull the links all the way closed or push them all the way open?
Here is a quick picture I drew to help illustrate:
Really, you think maybe the plastic plug magicly came apart and crap got in there? lol
Il .... how are ya, otherwise? It could be that the plastic clips that hold the rods to the door broke and it's just binding up. You should pull the door panel and take a look. If that is in fact it, the clips are cheap (any auto parts store) and easy as pie to replace. Or, like you guess, it could be the motor. The motor shouldn't be very much if that is the problem. Here's a quick Goo search ... http://www.slickcar.com/productdetai...?ProductID=552
Cheers! Let us know what you find out.
I've been having a problem, that might help you. Sometimes my passenger door doesnt get power, so the wndow wont work and when you try to lock or unlock the door, it wont do it. Nxt time you work on your car, open the door thats having the problem, if the door light comes on, then the door has power, then try to unlock or lock the door. If the door power isnt your problem, then sorry I couldnt be more of help.
Hope you fix it.
its your lock mechanism assembly which has the motor built into it. I have the same problem on one of the cars i'm working on, it could be fixed, but you'll have to take motor apart and adjust the electrical conntects if they're not too worn out. its easier to get another lock assembly. GL
I'm good. Trying to sell the Max which is why I want this problem fixed. I live in the boonies so I'm not scared of theft but for the other buyer, I want them to know their car won't disappear cause of a non-locking door.
What do you mean clip? There is one circular (somewhat) piece that the two rods going from the door handle/lock button go to...then it goes down to the motor. I sprayed WD-40 on that and it worked for one day. Is that the clip that is binding up?
Actually dirt gets everywhere, and the plastic plug can easily come apart, with just a bump. I've seen some odd hings while working with my Maxima, and when I had my old 1990 300zx. Things would come apart atthe worst times, its like the car is doing it.
Hope you fix it.
Hope you fix it.
There is usually a clip that holds the rod in place, it's a guide clip. All it does is support the locking rod. The rod slides in this clip (through it really) and if the clip snagged on the rod (or broke, they do that from time to time), then it would cause the lock to hang up. When you lock it by hand, does if feel ok? If so, then it's the lock actuator (motor) and that link I posted it was only $10. If the lock feels stiff or difficlut to move, then it's likely a clip haning up.
The motor that controls the lock is more of a actuator and is below the door latch. Yes I have one available for $20 shipped
So I finally got around to doing the replacement since it was chilly and my dad had the garage full with stuff he was working on.
All in all, a bit tough to get your hands in there to unscrew the old lock actuator but that's what it was. The lock actuator. My door works like a charm now.
Thanks Joe.
Thanks Joe.
1996 maxima
My passenger front door will not lock with the button or keyless. Handle or key works fine. I tried to remove the actuator, but cannot get it out to check the power. How to get it out, check it, and where can I get one?
vingodine
45
May 21, 2016 12:46 PM
delerium75
Aug 19, 2015 11:08 AM
shaunkey1
Aug 18, 2015 10:09 PM
CAN-Other LF: Worn / Broken Parts
george__
Aug 18, 2015 07:06 PM
kjm900r
Aug 5, 2015 07:14 AM
