check out my new B&M
installed yesterday took about 2 hours, should've took pictures during the install but didn't have time to do that. It's sooo much better than stock, I recommend to everyone. here's some pics, a little dirty inside, hadn't had time to clean.
http://www.google.com/search?hl=en&s...87&btnG=Search
OP: Check your shifter bushing, if it's still the OE unit it's probably pretty torn up. Replace it with a new OEM part or a polyurethane replacement and it'll help out the shifting feel quite a bit.
What exactly is the prupose? Does it shorten the distance between gears, like the distance between going from 1st and dropping into 2nd or 3rd into 4th? Or is it simply the height of the shifter? Been thinking of doing this when the remodeling is finished on the house and finally get some freetime, but was wanting to know the benefits first.
If you don't know what a short shifter is or does, I'd advise just googling it: http://www.twmperformance.com/short-shifter.html
www.velocityfactor.net
http://forums.maxima.org/5th-generat...t-adapter.html
http://forums.maxima.org/5th-generat...fter-03-a.html
Apparently both Stillen and Cattman also had the short throw adapters, have you contacted Brian?
magiconthetire
Oct 26, 2015 09:03 PM
