04 Max Brake Change
okay...the abs and brake lights were on before the brake change. it is my dad's car. i am going to run the codes on it...til then, does anyone have any speculation? the brakes have been working like the rotors are warped for quite some time and he has continued to drive it in this shape. the shake comes from the front, but the rotors didnt seem to be warped.
and i am thinking that it is related to the ABS sensors. tried to just clean the sensors off, and the lights stayed off ( even in reverse when i was braking) until i hit the brakes at a decent speed coming out of the drive way in drive. i guess i will be taking the rotors and assembly off, etc. how does one take the rotors off anyhow? i saw that there are two gold-colored key/spring thingies...that are likely to be tied to this process?
This will help.
http://forums.maxima.org/6th-generat...gured-out.html
its not the pads. its definitely something ABS sensor related. anyone know how to get the codes without going to the stealership? also...how the hell do the rotors come off? they are dirty as hell
Get a really long bolt and nut. Put the bolt through the hole where the caliper was attached and the nut on the side facing the rotor. Tighten the nut and it should push the bolt up against the rotor. Eventually the rotor will just pop right off. Cost me like $1 to get one at Home Depot.
MaximaDrvr
Aug 19, 2015 08:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
