Prestige XRO9100 Remote start and Alarm system NBIB
Old Feb 11, 2009 | 05:57 AM
Kof's Avatar
Kof
This is a NBIB system. This is a new model that was just released.
The system is pretty nice. And it has a color screen remote too!!
Below are the features
# 1 Two Way 4 Button 900 MHz OLED Remote Control w/ Side Switch
# 1 One Way 4 Button 900 MHz Remote Control
# Six Channel Code Learning Programmable Receiver
# External Superheterodyne Transceiver Antenna
# Single Or Two User Programmable W/Separate Control Outputs
# Can Control Up to 4 Diffferent Vehicles
# Single Button Lock/Unlock or Separate Button Lock/Unlock or Both
# Remote Keyless Entry With Optional Access Guard (must have power door locks)
# Selectable Manual Override Mode
# New Enhanced Panic Feature (Any button other than unlock stops siren, no change to the units state)
# Smart Disarm (If triggered, elect to shut off siren, or disarm entire unit )
# Adjustable Shock Sensor Via The Transmitter (Pre-Detect Off, Pre & Full Detect Off, City Mode)
# Safe Start Output Controlled From Channel 3 (Option Channel 3 For Trunk, Or For R/S)
# 24 Hour Time Start Mode
# Cold Temperature Start Mode
# 2 or 4 Hour Automatic Start Mode
# Parking Meter Count Down Timer On LCD Remote
# Additional Count Down Timer Mode
# Remote Panic In All Modes (Press & Hold Lock /Unlock Button For 3 Seconds To Engage)
# Improved Custom Code Override, User Selectable and Programmable
# Protected Push Button Valet/Override Switch
# 7-Function LED-Arm / Disarm / Zone 1 / Zone 2 / Zone 3 / Valet / Arming
# Intrusion Alert With Memory
# Instant Siren Activation
# Starter Disable Output
# Additional Engine Immobilizer Output, (Optional Relay Required)
# True Last Door Arming (Hardwire Only)
# Defective Zone By-Pass
# Defective Zone Chirp Confirmation (Unit Chirps To Report Zone Cleared)
# 6 Tone Mini Siren
# Car Horn Output For Additional Alarm Response (Improved Timing To Minimize RF Interference.)
# Additional Negative Trigger Input (Hood and Trunk)
# RF Inhibit With Ignition On
# Parking Light Flasher (Relay On Board)
# Plug In Dual Stage Shock Sensor (Pre-detect, Full Trigger and "City Mode")
# Audible Arm, Disarm, Defect, and Tamper Chirp Indications
# Headlight Control Output
# Illuminated Entry Control Output
# Active or Passive Arming Selectable
# Programmable Auto Lock On / Off
# Programmable Auto Unlock On / Off/Drivers Door/All Doors
# Programmable Door Lock Pulse Duration 1 Second / 3.5 Seconds/1 Sec L/ Dbl. U/L
# Programmable Active or Passive Door Locks
# User Programmable Permanent Chirp Delete
# On Command RF Chirp Delete from Transmitter Or Selectable Through Software
# Dome Delay Learn Circuitry (Patent Pending)
I am also including the necessary bypass module. This module is required for remote start if your key has a chip in it.
Price is $200 for everything
PM or reply if you have any questions
Old Feb 21, 2009 | 02:42 PM
wallyworl89's Avatar
wtb
how much for just the xro9100.
Call 845 518 1611 Walter
I can pick it up
Old Apr 17, 2009 | 12:09 PM
alarm
Can you still get me this alarm, I really need it soon b.c mine is breaking more each day.
Old Apr 17, 2009 | 12:12 PM
Kof's Avatar
Kof
Sorry I don't have anymore
Old Apr 19, 2009 | 02:58 PM
bksmax11203's Avatar
is this item sold already?
BkGreen97
Apr 2, 2016 05:47 AM
markevans999
Sep 10, 2015 04:29 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
