Ever seen an in-cabin filter with 200,000 miles on it?
I need help, I've tried to remove the glove box to get to the filter but I can't remove it, I took the screws out but still does not move. What I am missing?? I guess my filter is the same or worse than the one on the picture. I know there is a couple of DYI on this and I have seen the pictures, but I can't remove it.
experts please help.
Last time I changed my air filter, I had to remove the side door trim on the passenger side because my glove box wasn't going in. I spent 30 mins trying to get it in, then spent half a min to remove the trim and it went it.
Also, dont unhook those yellow wires, just unclip them from the glovebox assembly.
Wow!!!....Looks like that filter was doing its job!!!...
My 2000 maxima does not have any cabin filter-related labels in the glove compartment, so there is none installed, as it was an option on 00-01 models. I'll be ordering one soon. It will probably help me fight my seasonal allergies.
my 1994 BMW 325's filter with 170k miles was way worse. lol. The frame pretty much crumbled apart when I took it out, and I had a pile of leaves/sticks/etc. about 6 inches in diameter on my carpet after I took it out.
I need to do this for my maxima, but the damn filter is so expensive.
I just changed mine for the 2nd time since I've owned the car just this morning. My original filter was a one piece like the one RxMan put 200k on. I ordered my new one from DaveB and it came as two pieces. You remove a total of 6 philips head screws and please, please "DO NOT UNPLUG THE YELLOW AIRBAG SWITCH". Lastly, you may want to stick your shop vac hose in there to clean out some of the crap that gets left behind.
What I got from DaveB: a genuine Nissan filter part #999M1 - VP004
Health Warning Too!
If they get wet...you could develop mold, too. That stuff can get nasty real fast.
If you smoke and use "recirculate", you have a ton of cigarette smoke lodged in your HVAC system.
Finally...ever why your car smells old and musty??? Changing the filter & cleaning out the chamber might help.
I change mine every 40,000..and should do it 30,000. I procrastinate.
Vic
Your nose and that of those who ride your car attempt to do the work for the missing filter. My car didn't come with one either untill I put one last night. I found a good amount of dirt and dried small leaves sitting in there, only because they were too big to go through the fins of the condenser. Smaller particles have been passing though it and I have been breathing that.
i found out my 00se didn't come with that does anyone have a price on the part or can u get one from autozone or something. i know when i pulled out the heater core and changed it i found all kinds of leaves sticks and other crap lodged in to that compartment. and with my n my allergies i might wanna invest in one so i can breath better and help the car smell better
I know its the incoming side, but i have seen cabin filters with 30k on them that have had as much crap in them. I was wondering if there was a pile of junk (not in the filter) that was just sitting there because the filter had maxed out its ability to hold debris.
Maybe I should invest in a new filter. The car has had a distant but present funk since I got it. Post detailing and a bottle of freshener later it is still there. How much are they? do they have any Arm & Hammer ones?
I changed my filter in my '02 last Summer. If you are debating on whether or not it's a good idea to invest in a new cabin microfilter, just do it. You won't believe how much debris gets caught in that thing, especially leaves. Like the above poster said, make sure you have a shop vac or something ready, because there will be a bunch of crap left behind after you pull out, and if you don't get that stuff out, it will blow around and make annoying noises. But yea, this should be replaced at least every few years. Mine looked like it hadn't ever been replaced and it was worse than the OP's.
After checking prices at Amazon.com, Autozone and Advance Autoparts, I got mine at the latter. They all have the same part number (Beck Arnley 042-2038 Cabin Air Filter). $35 and some change out the door.
