Stalling and rough running while idling or at low speed
Please Help!!!
My 1992 Nissan Maxima SE with 132,000 miles now stalls at stop lights or in stop and go traffic.
It also runs rough at low speeds or while idling in traffic, and stumbles badly upon acceleration.
There is also a loud sputtering noise while accelerating at low speeds.
I’ve been trying to track down this problem for a while, but this is the first time that the car has actually stalled out while I was driving it.
I’ve replaced the cam position sensor, idle air control, spark plugs, O2 sensor, ignition coils, fuel pump, fuel filter, and PCV Valve.
I have also tested the EGR Valve and the MAF sensor and they both are working normally.
I’m not sure if this problem is ignition or fuel related, but it’s driving me absolutely nuts.
If any has any suggestions, please send them my way.
Thanks in advance for your help
Please Help!!!
Stalling and rough running whil idling or at low speed
Tested the injectors and they are fine.
Today I reinstalled the plugs and coils and resealed the gasket on the egr valve because of a vacuum leak. The stalling and hesitation on acceleration has subsided, but the idle is still rough at stop lights. While idling rough, the rpm guage wavers in between 750 and 550 rpm.
Any other suggestions given the current symptoms now?
also did you check your ECU for error codes yet? the check engine light rarely comes on on our cars, whether an error was detected or not.
My solution: Stalling and rough running while idling or at low speed
After multiple futile attempts to fix I took my ride to the stealership and had the diagnostic run for $98.00.
My problems turned out to be a number of things...
First and foremost the MAF Sensor was bad.
Second, Injector# 4 was bad; all others read between 11-12, and it read 5 when the stealership tested.
Third, the TPS was bad.
Fourth, the CTS was bad.
$235 in parts and 1 saturday afternoon and I am back running again. It runs smooth, but now it lacks the punch it once had. I think I'm done trying to fix.
I also found out that the fuel tank vent hose is leaking and the vtc's are clacking; I'm not fixing either.
I'm on the prowl for an I30; please let me know if anyone has one for sale!
Thanks again for everyone's help and suggestions!
sdotcarter
Sep 2, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
