my GXE plus some questions
Now onto my questions. 1) Not pictured are my rims whixh I will hopefully be installing this week and they are some 17's with a 235/45-17 tire and I was wondering if I go with a 2" drop will they rub? the rims are 17x7.5 and the offset is 40. 2) Where do I find the paint code for my car?
looks good, like the headlights
for the color # a guy told me to just go ask a nissan dealership for it. i was going to install a body kit on my 92 (decided not to yet though) and i would need the color # to paint.
i havent asked a dealership yet but if anyone by chance knows the color # of the light brown/goldish 92 maxima's and can PM it to me i would appreciate it
spacers?
i m running 300zx rims and they were rubbing on rear like krazy. i had to put 25mm spacer on rear well i dont really need 25mm spacer 18mm would do it....but on front theres no problem at all with factory height....however, if i lower it i will probably have to use 25mm on rear and maybe 10mm on the front with these rims cuz they r +45 offset lol...16x7.5
sorry for trying to get some help before buying stuff that won't work, so I guess im sticking with these rims and the stock height
correct tire/wheel/offset info for these cars is all over this forum, look around...
... 'cept she was a girl
anyhow, wheels have 5 critical measurements/specs: height, width, offset, lug pattern, and center bore size.
stock is 15", 6" (GXE) or 6.5" (SE), 35mm, 5x114.3mm, 66.1mm
after fixing my front suspension so i could finally hold an alignment, i decided to upgrade to 17" wheels.
- Originally, I rubbed the fender with 17x7 rims on STOCK height with 225/50/17 tires.
- Now i run 17x7 rims on stock height with 225/50/17 tires, and no rubbing.
so you gotta have all the pieces of the puzzle to know if it's gonna fit w/o rubbing.. just like greeny said (a few times). if you can't respond with an offset figure, then we can't help you.
that was the first thing i noticed in that pic...... all that work to make everything blue even the battery and u dont get blue distributor wires
u dont even gotta paint em ive seen bright blue aftermarket wires right outta the box...
) or i will have to find the EXACT spacer to put on the back so they wont rub...inside or outside which not really goona happen but i havnt measured it yet so cant say anything....so can u list ur rims specs with pics? spec mean everything...i will try to find the pic i took of my max and it exactly shows how far they sticks out on the rear with 25mm spacers...
i will recommend not to put spacers unless u have no choice left and only put hub centric spacers...not cheap ones from some local autoparts store which is gonna destroy ur lug nuts thread pretty badly...trust me i have gone through this....ONLY HUB CENTRIC SPACERS....safe as u have wheels on ur Hub....
Well I'm glad someone else posted about this so I didn't have to start another thread.... Offset is where you need to be concerned... And if you're going with a wide tire such as 235 or 245 then you will most definitely have to roll your fenders in order to avoid rubbing with such a steep drop.
Here's why I say such things.... 4dsc.com has some useful info on mustang rims and clearance... they say 17X8 rims with 235/45/17 are a "perfect fit" with no rubbing issues on a lowered maxima... "perfect fit" yes... they fit on the car no problem... do they rub with a moderate drop? (B&G Springs with Tokico Struts 1.6" drop) LIKE A MOTHER!... So the info is not wrong... but missing some valuable tidbits, such as what drop did they people that tested this out use?... So my suggestion to you is follow what everyone is saying about the offset (33-35 optimum) but if you're running wide tires don't be pissed at everyone because you dropped $600on tires when they rub.... You've been told.
tarun900
19
Dec 20, 2021 06:57 PM
Unclejunebug
Apr 2, 2016 05:42 AM
