1994 VG Check Engine Light On
My check engine light came on the other day and car has hard time staying running. My car normally doesnt like the winter but it is not real cold here in GA (55deg.) so I dont know why it is running this way or how to find out what the problem is without taking it in the but at the Nissan dealership. Can anyone help?
You can retrieve the trouble codes yourself on these cars..
How to access the codes--> http://forums.maxima.org/3rd-generat...-then-off.html
Code chart---> http://pages.cthome.net/bbachinsky/nissan_ecm_codes.htm
Check the codes, report back to this thread with the results..
I am getting this code too...
At least I think so (Code 13) Cylinder Head Temperature Sensor. Is this the sensor near the Fuel Pressure Regulator. I know some vehicles have more than one.
Thanks,
Aaron Harkness
Thanks,
Aaron Harkness
its coolant temperature sensor....and ya its near the FPR....RED one...not the blak small one thats temperature sending unit to ur temp needle on ur dash....change that CPS its easy to change....
See the little sensor to the left of the coolant temp sensor (red plug) that is the CTHS.
Ahh.. Hmm..
Well, I puled the connector and tried to squeeze the prongs a little closer together, cleared the codes and it came back. So, I am going to have to check tomorrow and see if there is a short in the wiring harness and if not I guess I will have to change it.
Could this be causing an intermittant knocking noise I hear around the firewall?
Thanks,
Aaron
Thanks,
Aaron
Maybe I should elaborate. I just tore down the top so that I could replace the K/S. that is why I am thinking maybe cracked a wire. They were pretty brittle. Maybe not, if I can find one locally easily I will just replace it.
no it isn't
it's the CTS (red sensor, for the OP's info)
the FSM says that a code 13 (on either VG or VE) is the "Engine coolant temperature sensor". look at EF&EC-259. just going on a limb here, but FSM > some random website
the ECU never sees the signal from the CTHS. the circuit for that goes from the fuseblock, to the cluster, to the sensor, and grounds on the body of the sensor.
ibbannedforaweek
it's the CTS (red sensor, for the OP's info)the FSM says that a code 13 (on either VG or VE) is the "Engine coolant temperature sensor". look at EF&EC-259. just going on a limb here, but FSM > some random website
ibbannedforaweek
no it isn't
ibbannedforaweek
ibbannedforaweek
i can't look at the fsm atm..(remember: dropped lappy)= pc freezes when i try to view any pdf..
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Thanks for your help!!
