Hub centric ring
Old Apr 19, 2009 | 07:44 PM
watson's Avatar
Hub centric ring
So I went and bought the rims that looked the best. I bought the RTX Lite-5 17x7 inch rims. Now I was told I need to buy hub centric rings. I am not too sure what those are or what kind I need to get. Any information on those would be greatly appreciated. Cheers!
Old Apr 19, 2009 | 07:52 PM
MROTH's Avatar
http://www.justforwheels.com/index.jsp?cat=hubcentric
Old Apr 19, 2009 | 07:59 PM
watson's Avatar
I already checked, they dont have the rims I have on there.
Old Apr 20, 2009 | 12:03 AM
mrjamaica98mx's Avatar
u get them on ebay for 9 bucks thats what i did
Old Apr 20, 2009 | 10:27 AM
MrDicks95SE's Avatar
Offset Is Everything.
find the bore size of the wheel and see if it matches the maxima's 66.1 center bore. if its larger, grab a set of hub centric rings that fit. if smaller, well you should know what happens.
FYI hubcentric rings are small plastic ring adapters that help the wheel sit properly on the hub. it makes it concentric with the hub so it spins perfectly with no wobbles or vibrations.
Old Apr 27, 2009 | 06:57 PM
watson's Avatar
K so I found out the size of the bore for my rims. They are 73.0, on the website that it shows to get them they only have 73.1 but not 73.0, what should I be getting?
Old Apr 27, 2009 | 07:08 PM
You don't need those sizes, you need to get the size of the bore on your car, which is 66.1mm
Old Apr 28, 2009 | 06:01 PM
Fr33way™'s Avatar
Wild for Width
I think he is talking about the bore of his aftermarket rim.
Old Apr 28, 2009 | 09:43 PM
IHAVEA2KMAXIMA's Avatar
Should do fine.
Old Apr 29, 2009 | 10:36 AM
watson's Avatar
Ended up just going to the rim shop and they got them for me. Close thread thanks
Andy29
Sep 29, 2015 05:32 AM
Pied
Sep 26, 2015 03:29 PM
londonflu
40
Sep 25, 2015 09:11 AM
DBear
Sep 14, 2015 08:33 PM
