so confused... injector colors
Old Apr 20, 2009 | 10:19 PM
johnno890's Avatar
i have a 93 gxe vg engine, cylinders 1,4,5 injectors are bad... i went to the junk yard and got 3 injectors still in the rail in which the guy pulled out and said the car was still running good but was wrecked. the thing is i just wanna make sure these will work my injectors are pink top but the ones he gave me are red tops from i think a 91. is it the same?? also i dont see the dot things like i hear about.
Old Apr 20, 2009 | 10:58 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
are the red-toppers style a () or style b ()?
if they are style a, they will not fit in a 93-94VG fuel rail (style b). i have both types of rails and one day test fitted to verify, and it is sad-but-true.
if they are style b, then i would think they are VE/VQ30DE injectors like i'm using. when i bought my 90, it had a 94 VG engine in it, including the style-b injectors (pink top tho), so it's very possible that the 91 you got injectors had the same thing, if they are also style-b.
Old Apr 20, 2009 | 11:23 PM
johnno890's Avatar
are the red-toppers style a (http://i164.photobucket.com/albums/u...0/IMG_1785.jpg) or style b (http://i164.photobucket.com/albums/u16/capedcadaver/pics%20taken%20for%20ORG%20members/1992maximase30/IMG_1787.jpg)?
the image has been deleted for style 2, have another pic??
this it the ones i got from the yard and i just noticed one of prone things are broken on the bottom as on one of them as seen in the first pic
Old Apr 21, 2009 | 12:24 AM
those are 259cc VE/VQ injectors..... VG uses 180cc. i am talking to someone about this right now on AIM, and he says not to use anything but the proper VG injectors. too much fuel can cause oil washdown, hurting the engine. which, after 2k miles on 259cc injectors, i might have done cuz i have an engine noise as of tonight
style-b link fixed too. it had included the ")?" with the link instead of after the link
Old Apr 21, 2009 | 01:57 AM
1993-VG30E-GXE's Avatar
Here's something that may help you. Cut and pasted into a TXT file from an old post somewhere on the ORG:
Pink= VG30E injector
Red= VE30DE injector
You need the pink ones..IIRC the oem blue or black dot injectors have been superseded into one on aftermarket injectors, not sure on this, maybe brian will chime in with true/false.
89-92 VG injectors are the same. Both Blue and Black dot injectors were superseded to one part # at all levels when new. (used/rebuilt is questionable depending on supplier)
93-94 VG injectors are still in 2 seperate #'s (green and yellow)****
92-99 DOHC maxima all take the same injector.
89-94 VG are all pink topped****
92-99 DOHC are all red topped.
I have currently running in mine a mix of Green & Blue dots. In a few days I'll be putting in a Yellow dot. For some reason from what I found, the yellow dot Bosch is slightly cheaper than the green dot.
Old Apr 21, 2009 | 02:17 AM
Here's one thing I don't get. There is a Bosch model that appears to have no dot but is listed as OEM for the VG. It's 45.00 more than the yellow or green dot. Don't know why.
Old Apr 21, 2009 | 08:07 AM
akurtzer57's Avatar
I thought all 3rd gen maximas even the VE were 180cc. Also werent the z32 na injectors the 259cc? Not trying to steal the thread just trying to clear some stuff up.
Old Apr 21, 2009 | 08:49 AM
internetautomar's Avatar
mod or sell?
that one is 89-92 VG, won't work in a 93-94 VG
Old Apr 21, 2009 | 10:01 AM
Good to know - thanks B
Old Apr 21, 2009 | 10:49 AM
VE injectors = VQ30DE injectors = VG30DE injectors = SR20DE injectors in terms of flowrate. several different sites said the same thing.
Old May 4, 2009 | 07:42 PM
WERNER1's Avatar
What are the actual differences between the Blue and Black dot ones (89 - 92 ),.. I never understood this, and could never get any info on this subject around here in my area ...
Old May 4, 2009 | 07:59 PM
Greeny's Avatar
¯\(°_o)/¯
IIRC, it is spray pattern differences, nothing more..
Old May 4, 2009 | 08:59 PM
WERNER1's Avatar
Hmm... can they be interchanged and mixed on the same engine? I've got some newer ones on my old engine,.. and this "new" engine has old ones on it that are a bit rough and of a different color (Don't recall which one's were on which engine at the moment - Blue/Black...)
Thanks.
Rick
Old May 5, 2009 | 07:13 AM
mod or sell?
Thanks.
Rick
they were combined into one part # by bosch several years back. IIRC black is the universal one
Old May 5, 2009 | 07:19 AM
WERNER1's Avatar
Gotcha,..
Thanks,
Rick
Old May 5, 2009 | 09:11 AM
nitrous360's Avatar
Yeah, this injector stuff is ridiculous. I just replaced all my injectors. I had green dots. I went with Standard injectors because I got them for next to nothing (a friend is a parts manager ) and the injectors were pink with no dots. I said a little prayer before installing them. Thankfully they worked out but it's just ridiculous how it's so damn confusing. There should be some number that all parts should have, even aftermarket, pertaining to the engine/vehicle/etc. This shouldn't be so difficult. JMHO
Thanks to this site for the nice injector tutorial. It made it much easier knowing what I was in for and I was prepared for the job. Everything went smoothly.
Old May 5, 2009 | 09:56 AM
WERNER1's Avatar
Uhm... where's this "Injector Tutorial" at??... I think I'd better get to reading through that right quick..
Old May 10, 2009 | 12:40 PM
93SCMax's Avatar
98 SE
This is confusing. I have a 93 GXE with pinktop /yellow dot injectors. I've seen 93's with pink top/ green dot injectors. I assumed the difference was the electrical connector, but both green and yellow dot have the same style B connector. Anyone know the difference between the green and yellow dot injectors? Can you mix and match? Thanks for any clarification you can provide.
Old Mar 19, 2012 | 04:54 PM
jona571's Avatar
help>>injectors 93 DOHC with one pink injector
I just got my new 93 SE and it has one pink injector up front dont know wats in the rear yet but will it make a diffrence in the way my car is running cause there does seem to be a problem with it
Old Mar 19, 2012 | 04:57 PM
mod or sell?
All VE motors take the same injector which is originally red with no dots. Over time they sometimes turn pink but still work fine.
Old Mar 21, 2012 | 01:55 AM
jona571's Avatar
Old Mar 21, 2012 | 12:18 PM
CMax03's Avatar
The thing you should be worrying about is the connector style on the VG's not the color! All 92-94 VG's had upgraded connectors that used the normal thumb release lever instead of that shi++y early style connectr with the lock pin around the base and required about 3 hands to remove!
Old Mar 22, 2012 | 03:37 AM
Hectic's Avatar
Or one hand, and a small flathead..
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
doctorpullit
Oct 28, 2019 10:58 PM
BobTX10
Oct 7, 2015 08:43 AM
