Wheel Fitment Question??
Old Apr 24, 2009 | 10:27 AM
Juiced SE-R's Avatar
Ok I'm mostly a motor guy that likes to play on the street/track but its time to do something to this car to set itself apart and not look so stock on the outside.. I took my D2 Coilovers off and am currently on Tein S. Techs due to my header install and Oklahoma roads. I'm looking at getting the flat black Volk TE37's in a 18x9.5 with a +38mm offset all the way around.. My stock SE-R wheel are a 18x8 with a +45mm offset. My question is will my current Nitto 245/40/18's go on this wheel? I think it will and a little bit of a stretched look is ok with me. Next question since I'm not as slammed as I used to be do you think I can pull this off all the way around without having any rubbing issues? I plan on rolling and maybe pulling my rear fenders a little just in case but I wanted to ask some of you what you thought.. Any insight on this will be greatly appreciated because I am ready to pull the trigger and swipe the card.. Lemme know please!
Thanks,
Sean
Old Apr 24, 2009 | 10:34 AM
NmexMAX's Avatar
dot dot dot ...
Wee bit on the wide side for me. And yes, those will have a bit of a stretched look IMO.
Old Apr 24, 2009 | 10:54 AM
But will they work without any issues and will those tires go on there ok? It is a bit wide but its diffrent which is what I'm shooting for, as far as Altima SE-R's go..
Old Apr 24, 2009 | 11:05 AM
NmexMAX's Avatar
dot dot dot ...
Take some measurements and do the math as far as the fitment goes.
1.) You know your current width (tire & wheel) & offset.
2.) You know what you're going to buy (tire wheel/width/offset).
Go outside and measure to check & see if there will be any issues. There shouldn't be, but it be nice to get an idea as to where things will be (outer edge of wheel / tire {fender well clearance} , inner edge of said wheel/tire {strut clearance}, etc.).
I'm not a fan of the stretched look, so I will kindly exit.
Old Apr 24, 2009 | 11:11 AM
Thanks for the info man
Old May 7, 2009 | 10:44 PM
thomatt12's Avatar
18 x 9.5s all around is actually quite wide for a Maxima. But if you could pull this one out, I'm sure it will look really dope. Don't forget to update us on this one.
__________________
shocks
Old May 8, 2009 | 12:04 AM
IHAVEA2KMAXIMA's Avatar
I think he has a SE-R, so that size MIGHT be pushing it for Altimas.
Old May 8, 2009 | 05:38 AM
BLACKonBLACK98's Avatar
Former Vendor
245 on a 9.5 is fine.
9.5 +38 will poke a little.
Old May 10, 2009 | 01:42 PM
[Shift Excitement]'s Avatar
I've got a similar idea, except I'm looking to swap the 5-spoke wheels from an 07' altima onto my car. Has anyone done this without having to modify anything? [edit] they are the 17" that come with the 3.5 se
Old May 27, 2009 | 09:27 PM
rehmankhan19's Avatar
Hey Guys! I am new to this Forum. HElp me out. I recently bought 20'' rims for 2005 maxima . My stock size is 17''. do you guys think it will fit in my Max? Someone told me that I need Adapters.. I dont even what kind of adapters do I need? Plz help me out
Old May 27, 2009 | 11:10 PM
Well... you already bought them, so just wait until you receive them and throw them up. If they bolt up and fit without rubbing then go get some tires.
JoshG
21
Sep 4, 2015 09:04 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
