00vi swap or buy MEVI
Old Apr 24, 2009 | 03:29 PM
tdewitt34's Avatar
I am wondering about this comparision. Which is better? which would give me more performance? I've read the posts & threads concerning both but I don't remember anyone posting a thread about the good and bad for both.? I want more from my max but which setup is better?
Old Apr 24, 2009 | 03:42 PM
pmohr's Avatar
No more Maximas...
You need to search more.
Seriously, I searched '00vi vs mevi'.
http://forums.maxima.org/4th-generat...ight=00vi+mevi
http://forums.maxima.org/general-max...ude-honed.html
http://forums.maxima.org/all-motor/2...ight=00vi+mevi
http://forums.maxima.org/general-max...ight=00vi+mevi
http://forums.maxima.org/all-motor/2...00vi-mevi.html
http://forums.maxima.org/supercharge...i-vs-mevi.html
'Better' is all subjective. Readreadreadreadread.
Then pick which you want; easier to install, less power? Or harder to install, more power.
But above all...search.
Old Apr 24, 2009 | 04:11 PM
T Keck's Avatar
pwnd
Old Apr 24, 2009 | 04:46 PM
tdewitt34's Avatar
Seriously, I did search but I did'nt find those threads all I did find was mevi or 00vi but not both
Old Apr 24, 2009 | 05:20 PM
whitealexander's Avatar
thanks for the link.. im looking for this one too..
Old Apr 24, 2009 | 07:38 PM
MaximaSpd85's Avatar
seriously, if youre interested in a full mevi kit, which is easier to install, i have one for sale....
Old Apr 24, 2009 | 08:21 PM
modenaf1's Avatar
'nuff said.
Old Apr 24, 2009 | 08:23 PM
pmohr's Avatar
No more Maximas...
Originally Posted by modenaf1
'nuff said.
Indeed. USIM FTMFW
Although to be fair, the USIM dyno was done with a stock ECU, the other two were with modified units...not a true comparison.
Old Apr 24, 2009 | 09:01 PM
modenaf1's Avatar
Originally Posted by pmohr
Indeed. USIM FTMFW
You mean USIM FTMFL?
And yes, definitely not a true comparison, but you can definitely tell by the shape of the curve that the USIM just absolutely starts to choke for air at the higher RPM's. And since the MEVI and 00vi both have the ECU, at least those two curves are a fair comparison.
I might add, one added benefit of going with the 00vi also is that you get the larger injectors and can tune via an AFC to compensate which actually advances the ignition timing. In other words, the 00vi is an opportunity to advance the timing a bit as well.
Old Apr 24, 2009 | 09:39 PM
MAX/GTR's Avatar
Go with the MEVI, its an easier solution less work involved
Old Apr 24, 2009 | 10:43 PM
blktalon456's Avatar
Since when? Don't make me hurt you. I want it LOL! Call or text me doodle.
Old Apr 24, 2009 | 11:42 PM
l3ftonm3's Avatar
Mevi + NWP Spacers for easiest route.
00VI for the more ambitious type.
Both are good choices, but the 00vi will have get slightly more power.
Old Apr 25, 2009 | 07:42 AM
Product_Of_Korea's Avatar
you would probley spend alot more $$$ on that setup vs a 00vi
Lately there has been alot of 00vi up for sale some as low as 250. Thats what i picked mine up for(but i bought the whole engine for that much)
They both have there pro's and con's. Personally i loved the 00vi swap you seem to learn alot in the process of it(which in my mind is priceless) But the mevi is direct bolt on which is very convient blah blah blah
Yeah i might be alittle biased. but in all honesty they are both really good mods
Old Apr 25, 2009 | 07:57 AM
wirelessdude04's Avatar
do neither spray the fwaker
Old Apr 25, 2009 | 10:24 AM
modenaf1's Avatar
True, the MEVI is an easier install, but with all the people who have done the 00vi swap and made websites, posted guides, etc. there is so much experience on here as long as you do all your reading and figure everything out beforehand, get all the parts ready to be installed, and if you start on a Friday night after work, I am sure even for the most inexperienced people on this board they could easily have the 00vi swap done by Monday to get to work again. Honestly, if everything is prepared right, I don't think it could take more than a few hours.
Plus, I don't know about you guys, but I absolutely love going out to the garage and working on the car, the 00vi so far seems like a really fun project.
Old Apr 25, 2009 | 10:29 AM
Yeah when i did it the 2nd time around it probley only took me 2 hours. but i just had to swap from one car to another
Eh 00vi and 75 shot=
Old Apr 25, 2009 | 06:06 PM
tdewitt34's Avatar
Okay I see all of the pro's and cons but now which would be more reliable? The Mevi or the 00vi? which has more issues? I want to have a upgrade but not the headache of fixing it constantly.
Old Apr 25, 2009 | 06:36 PM
Flava_24/7's Avatar
Boosted Panda
Neither should have issues. Once its one, thats basicly it. Other parts failing would cause issue, such as bad RPM switch, VSS, etc.
00Vi is going to be the the better power gain, but as all know requires more parts and more fabbing.
The MEVI with the spacers should yeild similair gains as the 00VI, but neither are really worth it with out an extended rev limiter.
Old Apr 25, 2009 | 10:20 PM
Coolsaber57's Avatar
Actually I've heard that cold start issues are pretty common with 00vi swaps
Old Apr 25, 2009 | 10:51 PM
pmohr's Avatar
No more Maximas...
If everything is set up properly, there won't be any issues.
A lot of the issues stem from people using the 4th gen IACV and having either too small of a hose, or have it too far away from the UIM, IIRC.
Old Apr 25, 2009 | 11:04 PM
mtrai760's Avatar
'Trynna' is not a word
I think most peoples issues are self inflicted.
Old Apr 25, 2009 | 11:28 PM
ColombianMax's Avatar
I've been thinking about 00vi, I'm still fairly new to the 4th gen so I'm not aware of everything. After reading from everyones comments I think I'm gonna start searching my local junk yards for an 00vi, thanks to the 2nd post on this thread, I dont have to search for the components I'll need anymore since all links are there.
After all, I may just find the 00vi dirt cheap. cheaper than the 250 mentioned earlier in this thread, especially considering most engines at a upullit yard cost 200 themselves. Got a nice cheap G35 sedan muffler for 12 bucks on wednesday
Old Apr 25, 2009 | 11:31 PM
pmohr's Avatar
No more Maximas...
Yea, really depends on pricing. At Crazy Ray's in Maryland, the entire 00VI could be had for right around $100...if you could ever find one.
Old Apr 26, 2009 | 01:25 AM
modenaf1's Avatar
At my local yard I managed the UIM, LIM, fuel rail, injectors, throttle body, egr block off, and injector plugs for under 100.
matts95max
Apr 23, 2025 10:44 AM
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
I<3 A32's
Sep 10, 2015 11:07 AM
iflexsteel
Sep 2, 2015 08:04 AM
