F/S ECM EXTEND HARNESS 4TH GEN /EMU LOOK AT PICS
This is a ecm extend harness that I made for a 4th gen it was made from parts from a 1996 auto maxima but I tryed it in my 96 5-speed and it worked great I also assume that it would work on a 1995 but I am not sure about1997-1999 would have to compare pin-outs.
This is the 2sd one I made the first one I used to put the ecm in my glove box and works great.. All of the wires are sodered and heat shrinked, every wires was test for connection also I installed it in my car and ran the car with no dtc's all the wires on the end that had the work done is coated to seal them up.
This is a great thing if you want to put in a emanage so you do not have to do all the wireing in the car. It takes about 10hrs + to soder all of the wires check them etc etc not to mention the time to destroy a ecm and harness.
Some of the wires are extended and may not be stock color so make sure when you make connections you check the pin location as well. What you see is what you get, it is just over a foot long any questions shoot me a PM
I do have enough to make one more but I can not give a time that I will have that one done. I am asking 225$ shiped in the us. given the time investment and the cost of the ecm and harness I had to destroy etc etc..
Well if you dId a emu you would have to make the connections but insted of doing them under the dash with very little room.. you could do it in the open.. and then you would not have to hack up your factory harness to do so.. I am going to look into making one for a 99 or see if this one will work..
ok so i checked the pin outs.. and there are some extra pins on the 99 that the 95-96 do not have.. I will have to get a cut harness end to do it.. if someone has a end I could do it up for ya.. I have a extra ecm end just need the end with the wires coming out of it..
tsi6001
Oct 3, 2022 10:23 PM
Finkle
Sep 27, 2015 09:53 PM
CAN-Toronto 2000 Maxima/i30 ECM
ChrisIve
Aug 22, 2015 03:04 PM
doobadoo
Aug 15, 2015 06:43 PM
