radio on 4th max
radio on 4th max
i followed the wiring instruction from crutchfield. when i use the CD player, the antenna goes up unlike our OEM CD player. crutchfield support agent said that is how it is wired for after market receiver. are you folks experience the same thing. thanks.
ok i have a radio problem. i pulled out the entire center column with the radio, ac controls, vents/defroster/clock panel, cig lighter, and shifter bezel. everything worked before removal. now when i tried to put it back, the radio will not turn on but the antenna goes up even of the car is off. as well the clock is not receiving power. i tested the voltage to the radio and with the car off it is only getting about 6 volts. with it running about 8 volts. i didn't screw around with the wiring or anything. what coule the problem be? any ideas/suggestions would be greatly appreciated!
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
