Clearance/Marker Lamp Keeps Blowing!?
Old Jul 21, 2009 | 05:23 AM
ghostrider17's Avatar
I've had my Fogs wired to my Clearance lights for almost as long as I've owned my car (7+yrs) and my passenger CLEARANCE lamp seems to suffer premature death as a result.
FYI: I ran an aux. wire into the fusebox direct to the clearance lamp to bypass the circuit, and tapped pwr to the fogs from there....
I now have HID's installed in the fogs, and run them quite often as DRL's.
I've now burned-out two sets of LED clearance bulbs (clusters) and even the grounded / shielded version that's SUPPOSED to be surge-proof.
This has been happening b4 the HID's came onboard two yrs ago, so I don't think they're the cause.
I'm no wiz @ diagnosing electrical gremlins....anybody got any ideas???
Bulbs seem to be lasting about 1 year regardless of make or style -- this CAN'T be normal??!
Am I missing an inline fuse between the fusebox and the bulb??? WTF?
Should I just STFu & keep extra bulbs on-hand for the imminent ANNUAL failure???
input welcome.
gr
Old Jul 21, 2009 | 05:57 AM
rvamaxima's Avatar
Did you have the fogs wired directly inline with the marker lights or did you do the fog light mod in the rely box? I have done 3 cars at the relay box with no issues. If your setup is inline you will blow lamps and possibly cause a short or worse yet an electrical fire.
Old Jul 21, 2009 | 06:04 AM
Relay box -- one of the original write-ups....can't remember who started that one....
It's been said that HEAT from the engine compartment can be bad for the LED's...but I go thru reg. Filament Bulbs ALMOST as regularly -- so i don't know if that's it or not?!?!
I'm probably just grasping for straws....just wanna make sure I'm not missing something here.
Those LED clusters are like $10ea. from Autoillumination!!
Might just go BACK to Filament style....but they look so YELLOW.
gr
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Noela
Sep 26, 2015 08:22 AM
conansriver
Sep 16, 2015 12:17 PM
