WTB : ONE wire from ecu harness
Old Jul 26, 2009 | 07:49 PM
sergofast's Avatar
I just installed a 96 JWT ECU into my 97 max and I have to rewire a part of the ECU harness so I dont get a CEL code.
I need one wire pulled out of the harness and about 6 inches of wire to do what I need.
Can one of you please hook it up?
It looks similar to this:
Old Jul 26, 2009 | 07:55 PM
maxfever1987's Avatar
which wire do you need i can help you
Old Jul 26, 2009 | 07:59 PM
sergofast's Avatar
It can be anywire that you can get out. I have to provide ground to pin 112 and right now its a blank spot in the harness (my car is a 97 and I have a 96 ECU).
If you have access to harnesses and plugs I could also use the plug that goes into the 00vi....
Old Jul 26, 2009 | 08:03 PM
so you just need any one piece of wire with 6 inch length?
Old Jul 26, 2009 | 08:18 PM
sergofast's Avatar
I need the female part of the pin and 6" of wire. Just that piece pulled out of a harness. Im going to take the pin and insert it in my harness so I can provide ground to that plug (this with the addition of swapping the 105 and 107 pins will eleminate the p0136 code that my ECU is giving)
Old Jul 27, 2009 | 09:00 AM
sergofast's Avatar
updated with a pic
Old Jul 27, 2009 | 07:46 PM
pmohr's Avatar
No more Maximas...
I've got a bunch of those pins in black. A few other colors as well.
Also have a connector that's been modified to fit the VIAS activation solenoid (locks on perfectly).
9aj9
Apr 5, 2020 12:11 AM
Kingofmaximas24
Nov 12, 2015 04:40 PM
