5.5 auto
5.5 auto
so after i went to the track to try at a PB this past friday, i had some really confusing numbers... my my previous best was 14.7@94 and a 2.3 60'
went this past friday and had a lil better run but times stayed the same...
2.22 60' 14.7@95... Now even with a better 60' and MPH i had no increase in ET's... someone care to explain??? my best 60' that night was a 2.19 but it was litterally right off the hwy with the car never even turned off to cool and i ran 14.9@92 but i can understand the car was probebly hot, but i let it sit for about 40mins with the hood open and it was a very cool (minimal wind flow) overcast weather, so im a tad confused... back to the drawing board this friday...
Times are confusing for me as well. My PB is 14.500 @ 95.99 mph. But last week I ran a 14.709 @ 96.2 mph.... and my 60 foot was better.... I guess somewhere mid track it lost a bit of power and then made it up again... Weird how that happens......
i think all cars need to launch at the right rpm or else it will bogg or if you try too hard it will spin, its all about finding that perfect rpm to launch at... Mine boggs if i leave to early and since ive cut down my old injen and made itinto a short ram ive gained a 10th but it will still bogg hard if i dont launch at high enough rpm
Its the rims and the weather.....when u ran that 14.7 @ maxus it was hot as a **** and u had them lightweight 16s on......and this time u went to the track wit the heaviest oem 17s known to man....lol.....but it was a tad bit cooler
So what u should do is go back to the track wit the 16s on and i garuntee that u come back with a new pb
That's not bad, I ran my best time stock l a few years ago (time below). Mine has always been strong for stock. I finally figures out how to launch it and got some good times, we will take it along with my 370z in September once it cools off. Now that its hot I can feel a slight reduction in power in both the Max and Z
What 16" rims? I was wondering which ones would clear the calipers..
there's a lot of 16's that clear the caliper... its 15's that u gotta worry about... i think he's gonna be using some 240 wheels, ill be using some acura legend (type 2) wheels... the 00 GXE 16's would clear etc ect...
I bet the DA was higher..? That would explain it. Since you got out of the hole better you trapped better, but since the DA was higher the car just didn't pickup power like it normally would so it kinda fell on its face, but the good launch got you the little bit extra trap speed..
????... did that make for any performance difference???..... im not 100% sure ill be running this friday anymore... as of yesterday, everytime i go over 80mph i see white smoke and smell oil after a stop... i want to fix my valve covers first.. but who knows... im just a bit paranoid
If you were referring to my post about the KS, I believe it was Neal that was encouraging the KS relocation. I know on my Altima, it made a difference due to the inconsistent behavior of the KS at times. You never knew on a given day how it would be running (power wise), some days it would be fine and run strong and other days, moms in minivans would nearly walk me...
Jeremy
Jeremy
well.. just got back from the track with a coule of the local orgers and a new PB... it was on the same 17's but with 2psi lower tire pressure (18psi) new PB
60' 2.238
ET: 14.5
MPH: 95.96... good to know im trapping almost a 96mph with a damn near stock auto maxima
im more satisfied now though there is clearly more to it... few pics too
muah!!!
me and phantom V who's best time before i left was 14.055 with a 2.2 60' 6spd
datdude20 was there, Jaypee99 was there... didnt stick around to see the times ghostmax and i forgot the org name for another max was there but didnt run
60' 2.238
ET: 14.5
muah!!!
weather was beautiful im not 100% sure, but temps were dropping and the car sat in the lane for about 1hr... mods are in my sig... basically, 4th gen ebay intake, custom 2.5" catback, nwp block plate...
OP: what do these cars run stock? I just bought a 02 SE/Auto and am curious to see what I can do with it... I use to have a 03/6MT that I went 14.2 w/just intake and full exhaust...but i'm use to a manual; so running the auto in a fwd might be tricky.
