Maxima Died, my mods to blame?
So I went to start my car yesterday and when it fired up the motor was knocking like a mother. At first it was very loud just because the initial rpm jumping to 1500 rpm then dieing down. Once the rpm was steady it was a continues knocking noise coming from the motor.
Now mods wise me and my brother did:
00vi
Lighter Fywheel /Clutch (didnt even break in the clutch)
Y-Pipe
EU + ext Rev
I did extend the rev limit to 7500rpm on the stock internals which could have weakend the crankshaft bearing or somethign else inside the motor.
I Havent taken apart the motor to see the problem I was just told by about 4 people the motor was finished, which is a pain in the *** as I invested time and money.
Im getting another maxima and will transfer all this stuff over. Any suggestions on what else should be done to increase the stability of the motor like maybe a rev up oil pump and valve springs?
Ohh the motor was very close to 260 000 kms which is about 161,556 miles.
Was this bad luck or just me?
00vi
Y-Pipe
EU + ext Rev
Maybe after extending the rev limit you revved the pee out of it and spun a bearing.
I'm sorry, but it sounds like it may have been your right foot responsible.
Mods wont cause the kind damage your describing, but they will allow a motor to run hard and fast enough to destroy itself where it may not have before.
Did you replace rod bolts? Main studs/bolts? Did you mod the bottom end mechanically at all?
Maybe you ran lean past 7k??
Are you sure its a knock and not some timing chain noise?? Does it come rapidly or is it delayed and random?? Is in constantly making the noise or is it every say 3 secs??
If i were you and your motor happened to be shot then i wouldnt grab another maxima. Id throw in a new motor........
Also if you were contimplating on putting in a new oil pump or HR springs or whatever then you should just do a motor swap anyways just cause its alot easier doing it outside the car vs inside the bay.
Have you tried going back to stock timing and stock fuel map???
Nope, just in the morning when I fired it up it made a noise like two squirrels fighting to the death...
The noise comes rapidly at first then maintains the constant knocking.
The reason im thinking of buying another car is because this one has some rust, the rockers are bad. Plus finding the damn motor is hard aswell.
I think all in all I either spun a bearing or something else with the crankshaft.
People have this issue quite often with vq's and usually drive them till they die instead of changing out the tensoner.
Also have you tried going back to stock timing maps and fuel??
So i take it your performance is down or not up to par??
Not really. A bad tensoner will cause chain noise but not really affect the cars perfomance.(unless you skip a tooth)
Some things to check:
-Did EU die? wires come undone?
-Any codes?
-Did you ever rev it high when cold? (past 3k)
Also, is it DEAD...or does it actually turn over but just has severe knocks?
-Any codes?
Yes thats what i mean. Turn all your maps back to zero and see if that makes a diffrence.
Do you know where in the engine bay where the sound is coming from??
Also is your perfomance affected by this??
The sound is coming from the left side of the engine bay. I havent taken it out for a spin as I did not want to test it out and have it go on me. Once I herd this noise I basically started it another 6 times on and off to show it to my brother,dad, and a mechanic friend. Then It was towed to my brothers friends garage.
Thank you very much for your smart *** answer, but I don't remember directing any questions at you.
I wasn't sure whether we have bolts or studs in the mains, or what the aftermarket offering is for that matter. All I was asking, was did he do anything to prepare his bottom end for high revving?
Well, we found metal shavings in the oil...So yah. Shes done.
Was under the impression these motors where bulletproof ^_^ jk...
If I find another max what would be some internal upgrades to safely run the car at 7.5k. By safely somewhat more controlled.
MAXSE5SPD
Aug 23, 2015 12:06 PM
Maxboy23
Aug 11, 2015 11:59 AM
