Racingbrake BBK 6th&5th GEN, Z&G
NEW PRICE 500
13" two piece rotors, 4 piston caliper, black. Fits 6th & 5th gen, Z & G, altima L31.
500!
Awesome brakes for dirt cheap
500!
Did you actually have this installed on your 6th gen?
Although the 6th gens use the same sized oem rotors as the 05+ G/Zs, I don't think this kit is compatible with all the above. IMHO, it fits either just the 6th/5th (probably 4th and 3rd if that's true) or just the G/Z. Not both. FWD and RWD Nissan/Infinitis have traditionally different caliper mounting dimensions making swapping brake caliper inbetween the two impossible (unless you have a bbk bracket specifically made to do so)
http://forums.maxima.org/6364589-post97.html
Did you modify the rotor or bracket in any way?
Can you detail what you did because in this post you said you had to space the caliper up 4.6mm I assume it was this kit you were referring to.
I don't get it. How is shaving the bracket going to give you more room? i guess I need pics. But if you alterned the mounting dimensions, then it will no longer fit correctly on a Z or G. Which goes back to my original statement about the mounting differences inbetween the 6th gen and the G/Z.
Essentially, this is a 6th gen / Altima only bbk now right? Still a good deal though
The gray area in the first pic is the part that was removed. The second pic is a side view so you can see it doesn't effect alignment. The valley is just slightly deeper all the mounting holes are the same. It allows it to clear the slightly higher spindle on a Max/Altima.
