3.5 Swap Questions
3.5 Swap Questions
I have been reading for days about all the swaps
The questions I have are
I see some people used the 3.0 timing.
Why change the timing stuff over?
I have a 95 se AT could I still keep the AT without doing major mods...Or would it be best just to buy the 3.5 with the 6spd and ecu ?
And how much nitrous can it handle vs the 3.0
I did find out I will have to buy the TB adapter from another org member
Ok so just swap the timing setup into the 3.5 along with a TB adapter from stephen and use all the 3.0 sensors and wiring I should be good ?
And make sure the o-rings stay in the oilpan
Almost EVERYONE swaps the 3.0 timing over. These are basic swap questions with which this section is rife. Please continue to read/search as it will probably answer every question you have and then some.
Ok just basically this is my setup
02 Maxima 3.5
Stephan max cam adapters
Stephan max Pathy TB adapters
00-01 Pathfinder Throttle Body
Full 3.0 Timing and upper and lower Oil Pans
New water pump & chain tensioners
6 puck Clutch
02 Maxima 3.5
6 puck Clutch
That helps alot
Dont look like a whole lot (besides the work involved lol)
JoshG
Sep 5, 2015 10:10 PM
