factory 99 catback interchangeable with 96?
Old Nov 22, 2009 | 08:02 AM
da God's Avatar
Can I swap out my banged out Rusty 95 cat+cat back with a 99 version?? i dont have 650$ to get the Greddy cat back.
Old Nov 22, 2009 | 08:53 AM
914max's Avatar
yea you can swap out with no problem
Old Nov 22, 2009 | 10:33 AM
da God's Avatar
awesome. was concerned about tthe extra pipe piece behind the cat for the o2. thnx for the quick response.
Old Nov 22, 2009 | 10:57 AM
Like already said it'll fit fine. That little extra pipe is not needed on your '96.
Old Nov 22, 2009 | 11:37 AM
tigersharkdude's Avatar
I thought they were a different length. hence why 95-96 greddy sp2 wont fit 97-99
Old Nov 22, 2009 | 11:58 AM
The reason the stock exhaust is longer is because of the S-pipe.
The '95-'96 SP2 will fit the '97-'99, you'll just need to add an O2 bung right behind the cat and it'll stick out an inch less than stock.
The '97-'99 SP2 will fit the '95-'96, you'll just need to plug the O2 bung right behind the cat and it'll stick out an extra inch compared to stock.
Old Nov 22, 2009 | 12:05 PM
da God's Avatar
thanks ChrisMan
Old Nov 22, 2009 | 04:57 PM
RA030726's Avatar
I'm nutty for Nissans
Wow you guys still cant get this one correct.
All 95, all 96, and 99 cali have a B pipe with NO O2 bung and its all one piece from the cat to the muffler. Supposedly early 97 may have this b pipe. The O2 is in the cat.
Later, if not all 97, all 98, 99 fed have an S pipe with a rear O2 sensor. The S pipe is bolted between the cat and the b pipe.
The total length from the cat outlet to the muffler inlet is the same on ALL 4th gens. The early B pipe is the same length as the later B pipe WITH the S pipe attached.
The 97-99 bumper is deeper so the 97-99 muffler has an outlet that is also a bit longer. Some aftermarket brands realized this and made 2 different muffler lengths.
Old Nov 22, 2009 | 08:57 PM
da God's Avatar
Damn. Drop the knowledge JSutter. Thanks again org.
Old Nov 23, 2009 | 01:47 PM
RA030726's Avatar
Yea I think this needs to be stickied.
my03maxima
Jul 28, 2024 07:40 AM
magiconthetire
Oct 26, 2015 09:03 PM
Justin Kroll
Oct 1, 2015 07:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
