Ebay Knock sensor's - any good seller's out there
Old Nov 27, 2009 | 09:13 PM
mbhang's Avatar
Hello,
I have had mixed results with ignition coils.
Bought 6 from a guy called Airflowtech - they worked for a week and crapped out - very shoddy construction - which was not apparent when new - but the heat of the engine sure made the flaws obvious.
Bought another 6 from a guy on ebay called golf6daysaweek - must say, much better experience. Very good coils - truly OE.
Now, I am seeing a price range of 20 USD to 120 USD on ebay for the knock sensors.
Anybody has experience with which seller is good (golf6daysaweek does not have knock sensors, or I would have bought from him/her).
Old Nov 27, 2009 | 09:37 PM
tosheto's Avatar
most people on here will probably tell you that all are decent and I would have to agree. I have $25 KS and it works great. just buy the cheapest one. it should work just fine
Old Nov 27, 2009 | 09:39 PM
I haven't seen any threads or posts about anyone having problems with an eBay KS.
Old Nov 27, 2009 | 11:36 PM
Shift_Nismo's Avatar
I paid $45 for mine on ebay, and it was OEM in sealed NISSAN packaging, so some sellers to sell OEM KS on ebay. You should be fine. Here is who I got mine from http://cgi.ebay.com/ebaymotors/GENUI...#ht_6048wt_923
Old Nov 28, 2009 | 05:40 PM
TravisCadello's Avatar
Do we need the KS? My check engine light is on for it but car still runs fine. and now i know i can get them off ebay if i need it ill get it.
What does the KS effect?
Old Nov 28, 2009 | 06:52 PM
hornepirate's Avatar
Search!
Old Nov 28, 2009 | 07:19 PM
RA021526's Avatar
I just made sure to get one that said new and oem. I paid about 50-60 shipped and haven't had any problems.
Old Nov 28, 2009 | 09:29 PM
When the knock sensor is out, the ecu goes into safe mode. The car will run "fine", but you will have alot less power. The KS is a ghost code, it doesnt trigger the CEL.
Old Nov 30, 2009 | 11:24 AM
cashoit's Avatar
KS wont trip CEL. U may have another issue there
Old Nov 30, 2009 | 11:36 AM
FallenOne's Avatar
to the OP did you get a chance to order one yet?
We need a bigger Search Button.
Old Nov 30, 2009 | 12:17 PM
mbhang's Avatar
Yes,
I have ordered one from Deutschepartsusa (ebay seller).
-- to the poster who indicated that KS would not trip CEL - That is correct, I don't have a CEL. However, the smog place indicates I am having timing issues (KS will retard timing), and therefore, I am trying to see if replacing KS fixes the timing.
Thanks,
Old Nov 30, 2009 | 12:23 PM
FallenOne's Avatar
Originally Posted by mbhang
Yes,
Thanks,
sounds good to me! good luck buddy
Old Dec 1, 2009 | 10:00 AM
Godzillamax's Avatar
+ 1 for Deutcheparts. Have mine in for 2 months with no problems.
Old Dec 1, 2009 | 12:14 PM
Celired's Avatar
Excellent! I bought one from Deutcheparts and am awaiting it's arrival, this makes me much happier knowing it other people have used this seller!
Old Dec 26, 2009 | 06:50 PM
felorojas14's Avatar
Just finished replacing my knock sensor on my 98 maxima. I bought on ebay for $48 from tennesseeautosales. Its oem so you have piece of mind. And it works great. I notice the difference in power
Old Dec 27, 2009 | 05:26 PM
gto400no1's Avatar
I had gotten mine off there way back in the day. Just look for ones that are oem.
Old Dec 27, 2009 | 05:38 PM
I thought it would trigger CEL. when i checked my CEL it had a few codes.
1-knock sensor
2-crankshaft position sensor
3-idle air control valve (Fixed)
Does anyone have a pic of where the KS is at? i want to change it but have no clue where it is at.
Old Dec 27, 2009 | 06:55 PM
internetautomar's Avatar
mod or sell?
1-knock sensor
under the intake manifold.
look in the stickies for a how to
Old Dec 28, 2009 | 11:42 AM
you serious? so pull off the upper intake manifold?
Old Dec 28, 2009 | 11:52 AM
mod or sell?
yes I am serious, but many have done it w/o pulling the intake manifold.
I will be pulling the lower intake when I do mine shortly since the upper is coming off to do an injector and I am half way in there anyhow.
Old Jan 2, 2010 | 03:30 PM
zagato27's Avatar
I recently bought a ks for my 97 Maxima SE on eBay for $22 shipped. Just installed it today. Have the cuts and scrapes to prove it. Here's who I bought it from:
chandlermotorsportsinc
No problems. Looks identical to the oem I removed. Cheers
kjlouis
Nov 24, 2018 06:09 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
maxinout93
Oct 27, 2015 01:29 PM
homeyclaus
Sep 3, 2015 06:15 PM
maxinout93
Aug 20, 2015 02:17 AM
