Oil Leak!?!
Old Nov 7, 2000 | 08:08 AM
Isaacm's Avatar
Hi guys,
I'm not sure exactly what is wrong with my engine, if anything. I was hoping someone could help me out. I just had my '93 GXE (112,000 miles) in for a few "routine" operations: water pump, thermostat, timing belt, new belts, and replacing two cam seals. Before I brought it in for all this, I knew that I had an oil leak somewhere, from the stains on my driveway. When the dealer (@#&*.,@!) inspected it, he said it was the two cam seals, and that would fix the problem. That was about 2 months ago, and I still smell oil when I am sitting still for more than two minutes. Last night I changed oil in it for the first time, and there is oil all over the underside above the drain plug. I check my oil level weekly, and it never seams to go down. Do I have a problem, or just need to clean my engine real good to get it all the old stuff off? Any help or advise is GREATLY appreciated.
Thanks.
BTW...Any of you guys from Minnesota?
Old Nov 7, 2000 | 08:19 AM
brubenstein's Avatar
Cleaning the engine is the best first step in finding an oil leak. On all the Nissans I've had, the oil filter was right above the exhaust pipe and very often some oil would drip onto the pipe causing the burnt oil smell (I know there is a lip around the base of the oil filter mount on the third gens to direct the oil onto the ground.) You can also have a bad gasket/washer on the oil drain plug. Also the oilpan hold down screws could be a little loose allowing oil to weep. The other thing to check is to make sure that it's engine oil and not power steering or transmission fluid.
Old Nov 7, 2000 | 09:29 AM
HotMax28's Avatar
Yeah if anyone else has some more ideas, I'm having the same problem with my '91 SE.
Old Nov 7, 2000 | 09:46 AM
Jeff92se's Avatar
I'm needing a caw
You had the timing belt done right?? I suspect a front crank seal but I would think they would have replaced that when they did the timing belt.
Old Nov 7, 2000 | 09:51 AM
Isaacm's Avatar
They charged me for all the crank seals, whether or not they did it is another question. I tend to trust them, being everything total cost me $1100!! Maybe they didn't tighten everything down good, or something like that. Maybe I should take it back to them and make them explain it to me. What do ya think?
Old Nov 7, 2000 | 09:54 AM
Jeff92se's Avatar
I'm needing a caw
For $1000, I would take it back and ask them what's going on. You may want to jack up the car and take a look but it does sound like it's coming from the front of the engine somewhere. ie.. where the mechanic has done some work already.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
