00vi Kit $250 shipped
Old Dec 18, 2009 | 05:56 PM
Mad-MAX_SE's Avatar
Still kickin'
I just got a hold of a MEVI, so I've decided to sell this 00vi setup I have had just collecting dust. It's a little rough on the exterior but can be cleaned up fairly easily (original owner was worried about any vacuum leaks due to being boosted, so there's a lot of sealant and JB weld on some areas), and some of the nipples have been replaced with new brass fittings. I was just going to paint it crinkle black, but never got around to it.
It includes:
- Upper Manifold (EGR blocked off)
- IACV Adapter plate
- Lower intake manifold (have a spare 4th gen lower as well that I can include if you wish)
- Fuel rail and injectors
- RPM switch (Summit I believe)
- Throttlebody - Sealed (cleaned it to almost new condition since it was diiiiiirty when I bought it - and coolant bypass tube cause you know you always wanted to!)
- '00 rear valve cover and gasket
- '00 rear coils
- '00 injector clips
- All the mounting hardware
The bad:
This setup was originally used by a turbo maxima, so the fuel pressure regulator is hollowed out; an eBay universal one will do the trick. You will also need a new set of the injector O-rings as the ones on the injectors are a bit beat up (some tearing).
So for about $60 this will be ready to rock and roll.
Pictures: Note, there might be a few hardware items still somewhat scattered in my garage not pictured, quite a few parts down there, I just grabbed all the big bits that I had in a box...
Old Dec 18, 2009 | 10:45 PM
tyler5619's Avatar
bump for a good guy.
Old Dec 20, 2009 | 08:28 PM
Mad-MAX_SE's Avatar
Still kickin'
Thanks for the bump.... Bump
Edited the original post.
Old Dec 24, 2009 | 08:04 AM
Mad-MAX_SE's Avatar
Still kickin'
bump
Old Dec 24, 2009 | 02:11 PM
KRRZ350's Avatar
WTF, how is this still here? This is a VERY good deal.
Old Dec 24, 2009 | 08:52 PM
nismomaxgtr18's Avatar
Wow....crackhead deal man GLWS. shouldve been gone by now.
Old Dec 26, 2009 | 02:03 PM
aackshun's Avatar
PM Sent.
Old Dec 28, 2009 | 07:07 PM
Mad-MAX_SE's Avatar
Still kickin'
sold
maxprivate
Nov 29, 2017 08:52 AM
Finkle
Sep 27, 2015 09:53 PM
fulloboost
Sep 12, 2015 08:03 AM
Maximeltman
Aug 31, 2015 01:01 PM
skinnypimp
Aug 28, 2015 11:45 AM
