Help with replacing front wheel bearing...
Old Dec 29, 2009 | 10:26 AM
myMAXse's Avatar
Looking for some advice on replacing the front right bearing. Can the hub assemble be removed from the axel without taking apart the knuckle?
Old Dec 29, 2009 | 10:28 AM
Love_00_Max's Avatar
NO.
U need to take the entire knuckle off and have the bearings pushed out. Not something u can do in the garage, take the knuckles to a press shop, they will push out the old bearing and push in new bearings. I like NTK and u can get it online at autopartswarehouse.com
Old Dec 29, 2009 | 10:56 AM
myMAXse's Avatar
Does the knuckle and the hub assembly come off as a single piece?
Old Dec 29, 2009 | 11:29 AM
Yes, they come off in one piece. I prefer to get a big press and a professional to pull and push new bearnings. A slight tilt when pushing can ruin the bearings. Just use the professional shop.
Old Jan 5, 2010 | 04:12 PM
CraigsMax01's Avatar
i am able to wiggle my wheel when all the bolts are tight, and u can see the cv axle moving also from the rear of the wheel. is this a bad bearing, (not to mention the roaring noise)
Old Jan 5, 2010 | 04:21 PM
fonz's Avatar
u have a bad bearing.the spindle comes off as one piece it is said that u can beat out the old bearing but pressing it out and in is so much easier,just did both of mine would recommend u do the same
Old Jan 5, 2010 | 05:18 PM
how many miles on ur car?
Old Jan 5, 2010 | 06:31 PM
vastmax's Avatar
deckdout2 does it for the cheapest locally...
http://forums.maxima.org/southeast-u...-bearings.html
Old Jan 9, 2010 | 04:48 PM
whats the best advice for getting the lower control arm bolt off of the spindle. seems to be a bytch. i have everything off and it wont budge. PB blaster is soaking on it now, and i want to hit it with a heat gun tomorrow.
even tried an impact wrench even though i hate to use it near delicate areas.
Old Jan 9, 2010 | 05:45 PM
turbizzy's Avatar
Were you able to get the nut off? Get the nut off, then use a prybar to pry between the knuckle and control arm while you bang on the knuckle with a hammer. It helps if you still have the strut bolted to the knuckle.
Old Jan 9, 2010 | 06:00 PM
rvamaxima's Avatar
I was just talking with Craigmax, the balljoint nut is froze. Impact driver wouldn't budge it. He hit it with some BP blaster and will try again tomorrow. I guess 200k miles of crud stuck on there will lock it up.
Old Jan 9, 2010 | 09:18 PM
00o30's Avatar
my Snap on got it off easily.
Old Jan 9, 2010 | 09:57 PM
turbizzy's Avatar
Shoot we get a ton of high mileage cars in our shop and we're still able to get fasteners off. But you guys got all that road salt crap huh.
Definately soak the hell outta it with rust penetrant, bang on it with a nice mechanic's hammer like a 32 oz or mallet and keep trying. If that still doesn't, put a 1/2 inch drive socket on it with a big cheater bar and keep trying. Sometimes the cheater bar is stronger than an impact. You can also spray the area with brake kleen and get it all cleaned up and use a torch to get the nut red hot glowing, it should take a few mins. Then quickly spray the knuckle and balljoint stud with brakekleen to cool it down while trying to avoid cooling down the nut and try the cheater bar again while someone bangs on the knuck with a hammer.
Old Jan 27, 2010 | 03:53 PM
STILO's Avatar
Are the bearings the same for auto and manual? Should we stick to the Nissan bearings or go to the shop and get the inexpensive choice?
Old Jan 27, 2010 | 09:35 PM
turbizzy's Avatar
Yes, they're the same. You know my answer to that, stick with OEM parts.
Old Jan 28, 2010 | 12:09 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Good timing on the pst My front right is shot, too. WTF is with that? (165k miles)
Old Jan 28, 2010 | 12:50 AM
DrunkieTheBear's Avatar
Turbo'd Saab
Both my front bearings went bad on my Grand prix at around 85k miles...the one hub bearing was so bad that it melted and bonded the hub metal to the axle...and it only just started humming about 2-4 weeks before that. I had to cut the axle to remove everything.
As fars bearings went on my maxima, I replaced all four at once at a shop when one went bad at 140k...I just said screw it lets break the bank.
Old Jan 28, 2010 | 09:58 AM
ColtMax's Avatar
Been through this 2 weeks ago... 185 000 km
Heres my contribution
http://forums.maxima.org/showthread....92#post7395692
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
twotonezed
Aug 16, 2015 11:41 AM
Samedi
Aug 12, 2015 01:54 AM
BassAddictJ
Aug 4, 2015 11:38 AM
