G35 19" rims on 03 MAXIMA. What tire size?
Old Feb 14, 2010 | 11:45 AM
perfectmax's Avatar
A few questions for those of you with g35 OEM 19" rims:
-What size tires are you running?
-Is your speedo accurate?
-Do the wheels come out past the wheel wells?
-Any rubbing?
-What suspension are you running (I'm thinking of H&R only in front with Tokico Illumina x 4)
Please post pics if you dont mind... Thanks!
Also thinking of maybe purchasing 06 Z wheels... I assume fitment would be the same?
Thanks guys!
Old Feb 14, 2010 | 01:58 PM
IHAVEA2KMAXIMA's Avatar
Pix and info can be found here http://forums.maxima.org/tires-wheel...s-maximas.html
Tire size calculator can be found here to find you the right size http://forums.maxima.org/tires-wheel...read-look.html
Old Feb 15, 2010 | 08:59 AM
yevrah4728's Avatar
I'm running 235/35's all around but mine is a 4th gen. I had to roll a little but they work. I'm on K-sport coilovers. I think the Z wheels are the same offset in 18", I dont think fitment is an issue with the 5th gens and those wheels, IIRC only 4th's have slight problems with them...
Old Feb 15, 2010 | 11:03 AM
timwdv's Avatar
245/30s
MR2 T'd
Jul 9, 2021 05:06 AM
minsbang
Sep 11, 2015 08:48 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
jfl330
Sep 4, 2015 01:44 PM
