speedometer stop working
Old Mar 1, 2010 | 04:16 PM
HotshotVQ35's Avatar
just out of the blue, went to pick up some dinner, and it just stops working. i was looking at the MT FSM, and i did not see any speedometer cable? I would think there would be one? my first thought is that it snapped, or became loose?
thoughts, ideas?
Old Mar 1, 2010 | 04:20 PM
Mr. Brett's Avatar
I'd say your best first bet would be to just pull the cluster and check for a loose connection. Usually the case. If not, maybe the motor for the needle.
Is it just me, or have you been having quite a few issues with your Max lately?
Old Mar 1, 2010 | 04:28 PM
i dont think so, car has been trouble free since day one, just having an issue with the abs, and now this. not bad for an 8 yr old car imo..
Old Mar 1, 2010 | 04:32 PM
Mr. Brett's Avatar
Well, okay, yeah, you're right. That's not bad for 8 years.
Did you get the ABS issue resolved? I remember seeing your thread.
Old Mar 1, 2010 | 04:33 PM
Rood's Avatar
could be the speed sensors.. Mine failed and the ABS light turned on and the speedo stop working..
Otherwise it could just fail, I believe the speedo is soldered in.
Old Mar 1, 2010 | 04:34 PM
Mr. Brett's Avatar
Actually, this was what I was thinking. But I wasn't sure if the speed sensor for the speedometer and ABS were directly tied or not, that's why I didn't mention it.
Old Mar 1, 2010 | 04:40 PM
Feldman's Avatar
i would guess either vehicle speed sensor or something happened in the cluster. I think i have a spare 02-03 cluster lying around if you are are interested
I put my money on the sensor though, i think it should be throwing a code
not yet, all the snow is melting, i should have a chance to look at it this weekend.
hmm..so maybe one is related to the other.. where are the speed sensors?
Old Mar 1, 2010 | 07:13 PM
e-subliminal-2's Avatar
Same happened to me when I installed my headers, Forgot to instal... Well not sure what cable it was but it's right up there near the fan. I caught it smacking up against the fan yesterday because the clip it was on snapped somehow.. Luckily I caught it just in time before the whole line snapped. I'd check that.. Maybe same thing happened but it ate through it..
gl man..
Old Mar 2, 2010 | 04:04 AM
Amave's Avatar
vehicle speed sensor.
Old Mar 2, 2010 | 11:19 AM
can someone tell me where the vehicle speed sensor is?
Old Mar 3, 2010 | 09:40 AM
its not the speed sensor, apparently when you pull the abs fuse you lose the speedo as well.
the abs problem is also gone. yippie for me..
Old Mar 22, 2010 | 12:24 PM
macsmaxima's Avatar
i have a 4th gen maxima and my speedo started quitting and the car would not shift until i tapped (or "beat") on the dash over the cluster w/my hand, it will then start working again and shift? i replaced the cluster with a low mile used set and fixed the problem for a week and it started messing up again (until i "beat" on the dash) any thoughts?
Old Dec 23, 2010 | 11:45 AM
RicanCoqui's Avatar
is it just your MPH gauge or is it all gauges?
Old Dec 23, 2010 | 11:59 AM
it was just the speedo, but now my abs light is on
Old Dec 24, 2010 | 09:40 AM
essential1's Avatar
My axles cry for mercy...
My speedo hasnt been working for months now. But I havent stressed fixing it because my odo isnt rolling over anymore either...
Old Dec 24, 2010 | 10:09 AM
foodmanry's Avatar
Da Roller Coaster!
You realize the vehicle also captures your mileage in the ECU right? If you ever go to sell that thing to someone you may have an issue...
Old Dec 24, 2010 | 10:15 AM
essential1's Avatar
I think i'll have an issue selling it either way. Nothing on the car drivetrain wise is original anymore. If I ever get rid of the car, it will be parted out.
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
