HELP! 2001 Infiniti I30 Moonroof won't open
There is no power, so I replaced the obvious, the switch, NO GOOD. I had the wiring to the switch tested to see if there is power to the switch, and there is. Now I was told to check the fuse, that's where I am stuck at now...I've checked every fuse in the 3 boxes under the hood and the 1 in the car on the drivers side. Can someone please help by telling me where to find the fuse that is for the Power Moonroof? I think my last resort would be to change the sunroof motor but first I need to find the fuse. Does anyone have any other ideas what could be the problem? It just stopped working! Any help would be appreciated...........
Did you disconnect the battery at all since last time you used the sun roof, if so you most likely need to reset the switch, the 02-03 Max's you just push and hold the switch in the off position for about 5 sec. you may hear it click a couple of times as it resets ... then just push the open switch as normal and away it goes. I am not sure on the reset procedure for 00-01, best try a search or two.
No I haven't disconnected the battery, thanks.....will try a search for resetting but wouldn't I need power first?
Here's the link for the FSM for the i30
http://www.nicoclub.com/FSM/i30/
Mar 12, 2020 12:06 AM
