What tire pressure are you running?
Originally posted by yo_its_ok
38 33
Maxximum Tuning Coilovers...1.7" down, Custom "tubular" Lower Control Arms, Poly bushings w/ Zerk fittings, Lower Tie Bar, Upper tie bar, front 1.2degrees negative camber, boxed rear axle, Maxximum Tuning "Race" RSB, Interior "X" Bar, Trunk "X" Brace, Toyo RA1 235/45R17 on 17x8 42mm offset Buddy Club P1 Racing, G-Tech Verified 0.94g w/ 1.0g+ when I spun out
-Peace
38 33
-Peace
you need to get some sleep...about 90% of the stuff you said i didn't get...but yo its ok
anyways...i am putting 33 in front 32 in the back
If you go too high on the psi range like 36+...what are the benifits?
36 psi isn't too high....
anyhow too low pressure you wear out the outer edges of your tires, lose some fuel economy and reduce handling performance for various reasons.
when th epressure is too high you wear out the center of your tire.
the right pressure is when you get an even temp across the foot print of your tire; inside, center and outside. I typicaly find factory recommended settings too low. Plus I like the firmer ride.
Test around 35 all around and start taking out air from the rear, and as long as it don't go below 32... you should find your range
Or is 35 never going to be an issue with that? Remember I got the MaxSpeed Lowering springs and the stock struts.
Dixit
Originally posted by spaaz14
Anyone know how to calculate optimum tire pressure? Acounting for; Load, general temp, weight distribution ect....
Originally posted by zgrm100
so what should i run with stock tires on the front and on the back. I drive long ditances and at speeds so what should i have?
. . . Anyone know how to calculate optimum tire pressure?. Acounting for; Load, general temp, weight distribution ect... . .
Nope. Too many variables not listed for which data is not readily available, like camber curves, tire characteristics, and perhaps most importantly on the street, individual personal preference. So you really are best off just to try different combinations and see what you like best. Basically the heavy end of the car wants slightly/somewhat more pressure and turn-in is enhanced with a little more pressure in the fronts.
FWIW, on the OE 225/50-17 RE92's I'm currently running about 36 - 37 front / 28 - 29 rear, which is enough of a pressure difference to dial out much of the understeer from interstate on-ramp charges. Yes, I know that according to the inflation pressure sticker my rear pressure is a little light, but since my car rarely has to carry more than two occupants or haul much luggage I can safely bias my tire pressures in favor of handling and hard cornering.
Words of warning: the above settings may be too "loose" for some drivers.
Norm
Norm
Re: Tire pressure
Originally posted by sllloyd
Does anyone know what the factory recommended tire pressure is? The manual says check the tires (Potenzas,) the tires just show max inflation pressure.
Norm
02nissmax
Sep 5, 2015 01:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
